Highbeam not working...
Old 15 Feb 2012, 10:49 am
supernasro's Avatar
Unhappy Highbeam not working...
Hello everyone !
Since I bought my Pt 2 years ago, the high-beam lights are not working.
I was thinking that the bulbs were the problem... but since I didn't need them, I never took the time to replace them.
I made some online research, and I found out that my car has two fuzes, one for Right headlight, and one for the left one, so that wasn't a fuze problem, since the low beam are working fine.
I checked the bulb of the high beam from the outside, and the spring that's in the bulb seems to be fine, and not melted, or cut... So I assume it's not a bulb problem...
What other possibility do i have?
I was thinking maybe it's the turn signal and light switch.
I found this one on ebay: http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en
and this video tutorial:
When I turn ON the high beam, the BLUE light (High beam indicator) on my dash board turns ON, but not the exterior high beam.
If you have a better video tutorial I would take it, because this one doesn't show a lot of details.
But what do you think?
Is it the switch for sure?
2003 Chrysler Pt Cruiser 2.4L 150Hp Tan
www.SuperNasro.fr.st >> Design [Go to]
Last edited by supernasro; 15 Feb 2012 at 11:00 am. Reason: Wasn't the right ebay part link
Old 15 Feb 2012, 01:26 pm
Default Re: Highbeam not working...
Could be the smallest hair line fracture in the lights I would change and try new bulbs before you go and change the MFS
03 gt atx mods are composite intake, big mouth bov lowered on drop zones with SRT-4 rims, full xenon urethane kit with 4" fog and 12000k hid, custome dual projectors, srt-4 front seats
Old 15 Feb 2012, 05:15 pm
supernasro's Avatar
ok, that's make sens
I will get new bulbs.
However, I would like to get a really bright light.. like the HIDs, or Xenon
Is the SilverStar lights looks like it?
Old 15 Feb 2012, 05:41 pm
I went to the Silverstars on the low beam headlights and fog lights. World of difference between them and stock bulbs. Makes the stock bulbs look yellow in comparison.
Old 15 Feb 2012, 07:29 pm
supernasro's Avatar
great! I can buy them with confidence then...
Where did you buy them?
And which one should I get for my pt ? I found so many of them!
Old 15 Feb 2012, 07:40 pm
Believe it or not, got em at Wal-Mart.
The low Beam Headlight are 9006XS and the fog lights are 9006ST (which means that the ends are bend down at a 90 degree angle.
Old 15 Feb 2012, 08:19 pm
Check and see if you actually have voltage at the socket before you spend you money on bulbs. If there's no voltage then you got to fix it first before any bulbs will be bright.
Old 04 Jun 2013, 03:59 pm
supernasro's Avatar
Hi,
It has been more than a year!
I didn't take care of that issue since then... But now I can have some time.
when you say:
You mean that I need to check with a voltmeter if there is voltage in where I plug the bulb?
I couldn't find them at Walmart...
Are those the ones I need? (I don't have fog lights):
SilverStar/Headlight (9006XSST-2) | 2003 Chrysler PT Cruiser 4 Cylinders B 2.4L SFI DOHC | AutoZone.com
Or those too?:
New Sylvania Silverstar High Performance Lighting Headlights 9006xs St 2 | eBay
And, how about the high beam?
Is it the same bulb? or a different one?
Old 04 Jun 2013, 04:53 pm
Originally Posted by supernasro View Post
...But what do you think?...
While the bulbs may be bad and replacing them is not "wrong", It might yet be a fuse.
...I made some online research, and I found out that my car has two fuzes, one for Right headlight, and one for the left one, so that wasn't a fuze problem, since the low beam are working fine....
Your car has two fuses for the low beams, but there are also two fuses (in series) that protect both high-beams. Check fuse #17, 15 amp in the under-hood PDC (might be #16). I know the other one is OK, as I soon say.
...When I turn ON the high beam, the BLUE light on my dash board turns ON, but not the exterior high beam....
That the blue light comes on shows power from the battery, through fuse #1, 25 amp (the one I know is good in the dash fuse block), through the multi-function switch, to a splice, to the blue light in instrument panel. All of these are fine.
From the splice, power circuit goes to PDC fuse #17, then both high beam filaments and grounds. The fuse or bulbs or sockets or all are bad. Or, the wiring circuits could be broken. Check the red/orange 16 gauge wire at the C105 connector (white) below/ behind the dash fuse panel.
My bet is on the PDC fuse.
Last edited by sanatanadharma; 04 Jun 2013 at 05:17 pm. Reason: fix quote formatting and fuse # (schematic says 16/17)
Old 05 Jun 2013, 11:28 am
supernasro's Avatar
Thank you for your reply!
Ok, I never had that much information about the fuzes... I'll check all of that and post the results =P
Thank you again!
A/C not working dexadel Tech & Performance Forum 98 03 Oct 2015 07:36 am
DRL not working 07BaLt Exterior Accessories Forum 10 25 Feb 2011 02:42 pm
Help a/c is not working just4kicks Tech & Performance Forum 5 20 May 2010 10:49 am
how to know the a/c is working? neps Tech & Performance Forum 5 04 Apr 2004 11:44 am
Still working turbomangt Vendors & Buyers Forum 4 29 Nov 2003 09:30 pm
