Ideas on LED bulb replacements for an 05' Touring
Old 16 Jun 2012, 09:05 am
Default Ideas on LED bulb replacements for an 05' Touring
I want to replace my rear brake lights and 3rd brake light with LED's. Any ideas on what the LED bulb numbers would be or what the best brand would be?
Old 18 Jun 2012, 08:27 am
Default Re: Ideas on LED bulb replacements for an 05' Touring
I replaced the brake lights with IPCW replacement bulbs - they listed equivalent bulb #s - their site has changed, you may have to call them.
Turn signal bulbs will require a resistor, or else your signals will be strobe lights.
The LEDS are MUCH brighter when I hit the brakes.
Old 19 Jun 2012, 10:41 am
Thanks Quicksilverdon.
When I GOOGLE IPCW replacement bulbs, all I get are sights that sell the entire housing with LEDs.
At the moment too expensive for my blood.
Does IPCW sell just the bulbs?
Do you know where I can find them?
Old 19 Jun 2012, 10:49 am
ROCKETMAN8060's Avatar
Here you can find the model number of the bulbs you need. Then go to eBay and search for the number but in led! For example 194 led!
Lamp Replacement Guide Home
ROCKETMAN8060
Old 19 Jun 2012, 10:51 am
Here you can see when I did mines
ROCKETMAN MOD'S
ROCKETMAN8060
Old 20 Jun 2012, 09:26 am
Thanks ROCKETMAN8060.
Love the mods. Especially the dual exhaust.
So if I understand correctly from your response to my bulb question; if the Sylvania site says that bulb 3157 is the tail light bulb then I just have to search 3157 LED? Is that correct?
Old 20 Jun 2012, 09:28 am
Yes Sr!!!
ROCKETMAN8060
Old 20 Jun 2012, 09:38 am
Thanks.
You have been a great help.
I just have to figure out which bulb is the 3rd brake light b/c the Sylvania site does not mention this.
I will remove the bulbs and compare them.
I assume the installation of the load resistor is imperative, correct?
Old 20 Jun 2012, 09:42 am
You're right, IPCW now doesn't list replacement bulbs, that's why I suggested calling them.
Resistors are needed for turn signals.
Old 20 Jun 2012, 04:47 pm
Do I need load resistors on just the turn signals or on all LED bulbs I install?
headlamp bulb out but 12v ok & bulb ok? Dwummer General PT Cruiser Discussions 13 19 Jun 2012 03:50 pm
VISORS original or replacements wasmussen Exterior & Interior Styling 2 08 Oct 2009 06:12 pm
Tire Rod End Replacements kappa_kruiser Wheels, Tires, Suspension 1 25 Jun 2009 12:39 am
Timing belt replacements ?? bob67firebird428 General PT Cruiser Discussions 3 18 Mar 2008 11:12 am
dash tweeter replacements? mikehrz Sound and Security Forum 1 18 Jan 2005 07:42 pm
