Heated Mirrors
Like Tree3Likes
Old 14 Jul 2014, 03:35 pm
Default Heated Mirrors
I have a 06 pt cruiser with non heated mirrors and want to install heated mirrors. Does anyone know if there is anything special i will need to do to install them? Are they on all the time or is there a switch in the cab that turns them on or ???
Old 14 Jul 2014, 04:27 pm
Default Re: Heated Mirrors
I have an 01 with heated mirrors and it does have a switch on the dash to turn them on. they also turn off with the ignition and will not come back on when car is started unless you push the switch again. you may also look at mirrors on an 01 or 02 that has heated fold in mirrors.
Old 14 Jul 2014, 04:57 pm
LionPT's Avatar
2006 came with heated mirrors, they should come on when you turn on the rear window Defogger.
Old 14 Jul 2014, 05:27 pm
....and so does the 2001. There's not a separate switch, it's all tied into the rear window defroster/defogger. The switch has a picture of a square window with electrical lines which is the same as the icon on the heated mirrors BUT it is the same universal icon for the heated rear window.
Old 14 Jul 2014, 07:05 pm
My mirrors don't have the heat symble on them.
Old 14 Jul 2014, 08:29 pm
LionPT's Avatar
Mine don't either, I think that was only from 2001-2002.
I also don't have the wavy line in #2 but a light where the red dot is.
Also, look to see if you have a fuse in slot #25.
Old 02 Nov 2017, 03:50 pm
I have a 2005 pt classic (ignore my username). Power mirrors, but not heated. I recently purchased some power, heated mirrors from a 2001 model, but the wiring connectors are not the same from the mirror to the door connector. Any quick solutions for getting these to work? Would the wiring inside the doors of the 01 model make this easier or is there a simpler work around? Thanks for your replies!
Old 06 Nov 2017, 09:23 am
I added heated mirrors to my car by using a pigtail connector to replace the connector located behind the door panel. I cut it from the same car in the salvage yard that had the heated mirrors I took. Then you can splice in the new connector and run a new wire through the door for the defroster.
wingman55 likes this.
2004 Touring Turbo Lite, Hahn 20g turbo, ATX ->T350 5-speed swap, mtx stage 1 pcm, DiabloSport InTune, rear sway bar, Wilwood big front brakes, rear disc brake conversion, Drop Zone springs, SRT4 dual exhaust
Old 06 Nov 2017, 10:42 am
Thanks. That's what I thought was needed, but after having the parts shipped to me, I forgot to ask them for the pigtail in the door. Now they won't cut apart the door wiring even though the car is destined for the crusher and want $25 for each door wiring harness + shipping....so probably another $100 total. I was hoping for another option (if feasible or possible)?
Old 07 Nov 2017, 07:34 am
svtnos's Avatar
on my 03 i just bolted on 01 heated folding mirrors with no modifications and they work perfectly..
2003 PT Cruiser limited edition
Heated mirrors question. JoeCruiser Exterior Accessories Forum 7 29 Oct 2012 12:10 pm
Heated Mirrors? lmnopq General PT Cruiser Discussions 2 12 Apr 2011 01:30 am
heated mirrors.... rockrtboy General PT Cruiser Discussions 4 09 Jun 2006 09:10 am
Heated Mirrors WAYNEF General PT Cruiser Discussions 8 04 Sep 2003 12:27 am
Heated mirrors. iownacruiser Tech & Performance Forum 2 26 Apr 2003 01:54 pm
