Mounting Aux Driving Lights
Like Tree8Likes
Old 22 Nov 2014, 12:03 am
podo2000's Avatar
Default Mounting Aux Driving Lights
I do a lot of rural night driving and all my other vehicles have Aux driving light, like a 6in round PIAA/ Hella type. I want to put something like that on the Cruiser. Just to clarify, not the lower fog light position. Any suggestions on how to mount them?
Thanks
2004 PTGT 135Kmiles
Old 22 Nov 2014, 01:04 am
Default Re: Mounting Aux Driving Lights
a bit hard,
1. take our exsitng fogs and replace them and cut to fit,
2. you can squeeze a thin par of lights behind the top grill,
3, cut holes in the plastic bumper and holes inthe steel bumper insert,
4 Xenon Custom Body Kits
bruiser front bumper fasica kit
5. where you see the lights on the bruiser front end, you can cut into the same stock bumper in that location and mount some lights about there
6. offroad style, make a simple braket that mounts where the fender tops meet and hood closes over, and make braket beyond the grill area and mount what you like ,
7 like this
8 or this
mount lights right on frot tbumper and drill holes through plastic bumper ito the steel then use self tapping screws to fiish the mounting
Old 22 Nov 2014, 01:24 am
podo2000's Avatar
Thanks Turbo. #7 is what i had in mind. Any idea how that bracket is mounted and stabilized? Looks like its attached to the front plate bolts
2004 PTGT 135Kmiles
Old 22 Nov 2014, 01:29 am
yes its off the front lp bolts,
personaly
i would go on the side of thouse bolts and drill right into the steel bumper and bolt down tights, then cut the lp mount to let my braket arms out dont think the plastic will be so strong, i want metal,
and i would make mins so high right above the bumper would be nice
podo2000 likes this.
Old 22 Nov 2014, 02:31 am
podo2000's Avatar
personaly
I will look int that this weekend. Will post updates along the process. Thanks
NitroPT likes this.
2004 PTGT 135Kmiles
Old 22 Nov 2014, 06:40 am
LionPT's Avatar
There is a member here with a Black PT that has a set mounted on the front bumper...but I can't remember who. I'm sure someone else will.
Old 22 Nov 2014, 08:20 am
There is no metal behind the plate mount. 2 1/2" of foam between the cover and the reinforcement. Might come from behind the bumper between the grille and bumper cover with a plate to mount lights up high. Or the bottom for lights at bumper level. With the plate coming from the back of the reinforcement the license plate bolt holes can be utilized for stability without going all the way through to the bumper reinforcement.
Old 22 Nov 2014, 09:56 am
LionPT's Avatar
I almost posted that the user I was thinking of had a light on each side of the front plate, but I wasn't sure.
Old 22 Nov 2014, 10:12 am
I know what cruiser that has some. But like you I forget his handle. Black or blue one. Diamond plate polished.
Old 22 Nov 2014, 11:09 am
rckstein's Avatar
It's "garkeller" but I can't get to any pics in his album to post one here, but he has the lights mounted on a plate below the license plate.
Busted_PT and LionPT like this.
Add I fog/driving lights? j0e General PT Cruiser Discussions 7 01 Apr 2014 07:05 pm
Where should I aim driving lights? shelbyzman Exterior Accessories Forum 8 08 May 2013 04:55 pm
aftermarket driving lights or chrome out where lights would be? shelbyzman Exterior Accessories Forum 9 03 May 2013 02:28 pm
Driving Lights Come on by themselves? sscanlan Tech & Performance Forum 3 02 Apr 2011 02:31 pm
DRIVING LIGHTS MELTING Crash Exterior Accessories Forum 1 30 Nov 2001 03:06 pm
