Best "BLING" for the buck on new rear tail light assemblys
Like Tree2Likes
Old 14 Jun 2015, 08:48 am
ptprice's Avatar
Default Best "BLING" for the buck on new rear tail light assemblys
Well I did the impardonable while diagnosing a bad socket on my left rear turn signal.
I not only broke off one of the tiny lock clips on the connect assembly that hold the wire leads. (The wires that come through the fender wall from the loom into the bulb socket assembly in the interior of the tail light assembly's.)
Of course I lost the little piece on the ground as I was trying to hold it steady with needle nose pliers and reattach it with super glue because of my pre-palsy tremors. My only recourse was to get down on the 125 degree asphalt and search for it. (No luck). @#$%^&*(!)_+|
The lead assembly did show 12V power when the turn signal is on. But don't get any continuity in the socket assembly so I guessing previous corrosion and sitting unused for 9 weeks have left it irreparable. As I want to keep SOO BIG in pristine condition, I'm off to the the junk yard this AM to find some good bulb socket assembly's and another lead assembly with both holding clips that I'll splice in hidden behind the plastic storage panel area. That's right, all that panel has to be pulled out for access.
Unfortunately that's not the end of it. As I reinstalled the left tail light assembly my pre-palsy tremors got the best of me and I broke the assembly.
Which, after this diatribe, comes to my question; does a Forum member have a good used 2005 left tail light assembly I could buy economically? Or should I go "BLING" and use this as an excuse to get a set of chrome ones. I'd prefer the ones that have a some what original shape and not the stacked dimensional look of some of the chrome aftermarket offerings that take away from the original lines of the PT. I've spotted a few in the $65 to $95 range but they all appear not to come with socket assembly's, just the openings and in enlargement the appear to have a rubber edge. Also, do the chrome ones have a good life expectancy or does the chrome lift in time? I'll throw this long thread out and hope for advise. More pix of the "new" SOO BIG to come. thanks, ptpprice
Old 14 Jun 2015, 08:57 am
Default Re: Best "BLING" for the buck on new rear tail light assemblys
Post some of the aftermarkets you like and maybe someone has some they want to get rid of and save you some bucks. Shipping will have to play into any money deal . But it worth a shot.
Old 14 Jun 2015, 03:09 pm
ptprice's Avatar
I don't know how to "post an add to the Forum. I need some instruction?
Relatively speaking though I have found a few chrome tail light assembly's, priced with-in reason that I like.
I'd wondered, as I mentioned in the first thread, that they look like they might have a rubber surround, do they?
What is the duration of the chrome tail light assembly? Do they peel and deteriorate?
The trip to the junk yard was successful and I got a few goodies I'll post later on. Right now I must hydrate,(Yuenglings) shower, make an egg salad sammich and watch Danica run in Michigan. ptprice
Busted_PT likes this.
Old 14 Jun 2015, 03:47 pm
If you want to keep it looking somewhat original, I'd go for the tail light rings. They can be had on eBay or here's a link to Maggie's Race & Street ad. The ring will hide your mishap on the edge of the light.
Race and Street: Chrysler PT Cruiser Taillight Rings - Chrome - Autotecnica
Old 14 Jun 2015, 04:21 pm
rckstein's Avatar
I had to recently replace all 4 pigtails on the taillights on my PT as the clips broke, I guess they just get brittle from age. But you don't have to replace the entire wire loom, you just need about 6" of wire from the connector and some butt splices.
Old 14 Jun 2015, 05:23 pm
A little suggestion for the future work of this type. Lay down a comforter to pad the fall and collect the dropped peaces. Easier on the knees as well.
Old 14 Jun 2015, 09:21 pm
ptprice's Avatar
I stumbled around pull-n-pay today and got enough "stuff" to fix the nonfunctional left turn signal socket, so a wire splicing will be hidden behind the plastic rear storage panel to install a replacement connector end to plug into a functioning socket.
I've temporarily superglued the broken taillight assembly back together and will reinstall it in the cool of the morning tomorrow.
I'm still looking for chrome "BLING" taillight assembly choices other Forum members have had luck with.
I"m still in the dark about pulling images of chrome tail light assembly,s that interest me, from an internet add to a Forum thread as Busted PT suggested. How is this done??? ptprice
Old 14 Jun 2015, 10:04 pm
rckstein's Avatar
Here are a couple of choices that I found on Amazon, ebay would also be a good source as there are numerous choices:
Amazon.com: Spyder Auto Chrysler PT Chrome Cruiser Tail Light: Automotive
Amazon.com: Chrysler Pt Cruiser Chrome Altezza Tail Lights Rear Brake Lamp: Automotive
Old 15 Jun 2015, 03:44 pm
ptprice's Avatar
rckstein, the smooth Chrome tail light assembly's are exactly what I'm looking for. I found this same set on an eBay site selling them for $79.99
Do you know if this style has a rubber edge or is it solid plastic, much like the OEM tail light assembly's. There's enough rubber to fool with and hide around the head lights! Please, if possible advise through my email address; priceyoungman@hotmail.com. This seems like the best price, shipping is included so I'd like to take advantage of it. I still don't know how to transfer an internet add to a Forum thread. Thanks ptprice
Old 15 Jun 2015, 06:04 pm
rckstein's Avatar
I don't know of any taillights that have a rubber edge. The last time I replaced my taillights, I got some weatherstripping from Home Depot and put it around the entire edge, on the back side, to fill the minor gap between the lense and body.
Rear "woody" panel chipped, cracked and peeling 02LimitedEd Exterior Accessories Forum 1 13 Dec 2013 08:18 am
Installed my spec-d "smoked" tail lights shelbyzman Exterior Accessories Forum 29 03 May 2013 02:24 pm
"Subdued Elegance"s BU light switch died sanatanadharma Members PT Project 1 21 Mar 2013 06:48 pm
Turbo "phhsssss" or "whoosh" sound--Normal? Silenceable? Help! Memark General Turbo Discussions 13 24 Nov 2010 10:56 pm
