OEM Ground Effects!
Old 11 May 2004, 10:39 pm
Default OEM Ground Effects!
Bought the OEM Ground Effects from 'Wyckof'for my 01, really nice quality! Question is, before I go all over town, can anyone give me an idea how much $ we're talking to have them painted and installed. I'm thinking of taking them to a dealer (know the price is higher) for the install....any help?
Old 11 May 2004, 10:59 pm
Which ones. the flat panels or the newer rakish ones?
You could prolly install them yourself, but I would bet on 300 if you had rocker panels and front and rears done.
Homepage:
Old 12 May 2004, 09:28 pm
PTGT REDMAN...THANKS FOR THE INFO. I WENT WITH THE FLAT SIDES. I REALLY THOUGHT ABOUT DOING THE INSTALL, BUT I WOULD HAVE TO GET RAMPS, JACKS, ETC.
Old 12 May 2004, 10:28 pm
np. did mine in my garage. Even with ramps (35 dollars for the plastic rhino ramps at Pep Boys), could not bolt on the rocker panel tabs under the car.
Still, only need a rivet driver (16-) and some rivets (2-3 bucks)
Few hours in the garage and was done. No prior experience. Hey at least if you screw it up, you can only be angry at yourself. pay someone else to hack it up then you get agry at everyone.
Homepage:
Old 13 May 2004, 06:02 pm
Only needed rivets??? The instructions with my new Mopar Hot Body Kit required using a paper template to cut 4 slots (both the front and rear facias) for a tab on the backside of the front air dams and rear spats to fit into, which are then clipped from the backside of the panel. Then drilling holes for pop rivets down the side panels and lining everything up for 3M tape application. And, you definately need ramps or a lift to get the car off the ground to do this install. An extra set of hands when lining up the side panels helps, too.
It looked like a lot of work to me and I'm a bit mechanically challenged. So, I took my 2004 DC3GT down to the dealer for the installation. Charged me $187.50, and it took them a lot longer than this standard 2.5 hour labor charge to get it right. Looks great, though and if the dealer messed it up, they'd pay to correct it. Was worth the money to me.
Tom \"Terrific\" Myers
2004 DC3 - \"Dreamweaver\"
Phoenix, AZ
http://www.cardomain.com/memberpage/578198
http://www.ptcruiserworld.com/DreamWeaver/
Old 13 May 2004, 06:17 pm
K. You perogative. I am a do it yourselfer. I have seen the kits installed by the dealer on the lot and they looked like sh-t.[8)]
Homepage:
Bumper cover (Ground effects) Grayscruiser Exterior Accessories Forum 13 24 Oct 2009 03:05 am
mopar ground effects and probably keeping the car VellianPT General PT Cruiser Discussions 1 08 Apr 2005 10:44 am
'WANTED' ...OEM Ground Effects! 1lowufo Classifieds: Want To Buy 0 25 Apr 2004 06:27 pm
OEM Ground Effects 1lowufo Exterior Accessories Forum 3 24 Apr 2004 07:48 pm
neon ground effects beard General PT Cruiser Discussions 5 18 Mar 2004 06:01 pm
