Sunroof Glass?
  • 1 Post By JoeX
Old 03 Aug 2015, 11:24 am
SPLNeon's Avatar
Default Sunroof Glass?
Can the Sunroof Glass be removed from the Mechanism? I'm wanting to delete the Motor, and tray, etc from the sunroof.
Fastest fwd PT Cruiser in Canada
Competition's paying the price.
03 PT GT. DSI canned tune, Weight redux, MH Racemaster Slicks/Rota Slipstream 15" 11.89at 115mph 1/4 mile
96 SOHC Neon Turbo
08 CSRT4. Realtune MS1K v1 pcm stg0 NSRT4 Injectors.
Old 03 Aug 2015, 12:17 pm
Default Re: Sunroof Glass?
just use safety glasses, long sleeve shirt, gloves and a hammer..one quick swing should do it!
Old 03 Aug 2015, 12:26 pm
SPLNeon's Avatar
LOL, was thinking that too, I do have some polycarbonate to go in its place if I do break it lol.
96 SOHC Neon Turbo
Old 03 Aug 2015, 12:46 pm
Handy_Cruiser's Avatar
Yes.
Put the sunroof in the vent position and there are two torx head bolts on each side. Remove those from inside the car and the glass lifts right out.
Even if you remove the entire mechanism and replace the glass with a piece of plexiglass with a rubber gasket, it still makes it easier to remove the glass before dropping the mechanism.
Here's a thread where I changed mine out.
The Handy 2005 GT Modification and Upgrade Thread
Old 03 Aug 2015, 06:35 pm
SPLNeon's Avatar
Perfect, Thanks!
96 SOHC Neon Turbo
Old 03 Aug 2015, 06:52 pm
I removed the mechanism with glass in tack. Reinstalled with glass in also. I did this without any help. Wasn't hard.
Old 03 Aug 2015, 11:45 pm
As you probably already read above it easy to remove but keep in mind the track for SunRoof is also a rain gutter with 4 downspouts to keep your interior dry
Busted_PT likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 04 Aug 2015, 03:58 am
SPLNeon's Avatar
Yup, this car sits in the Garage 90% of the time, so won't see much precipitation if any :-)
96 SOHC Neon Turbo
Old 04 Aug 2015, 01:31 pm
will they let you run it with the sunroof removed? people would just think it was open.
Old 04 Aug 2015, 02:18 pm
You are more of a man than I am. I removed the glass to lighten the weight and then got my son to set one side while I got the other so the mechanism wouldn't fall on the head liner. It was very quick since I didn't have to removed the glued-on electrical wires from the head liner. But it was a two-man job while removing and installing the mechanism
Also for the OP, you can usually buy that generic rubber window gasket off of a role at many glass shops. I used to buy it regularly when we used to refurbish heavy equipment. Most of the stuff we got in to work on had all the glass knock out of the cab. If you make a pattern out of cardboard, the glass shop may be able to sell you plexiglass and cut it to shape for you.
cleaning glass 4SPEED The Detail Shop 3 21 Apr 2011 06:18 am
glass tinting badzy Vendors & Buyers Forum 1 04 Aug 2008 07:50 pm
Glass towels turbomangt The Detail Shop 4 16 Aug 2005 08:55 am
Liquid Glass? amazingarthur The Detail Shop 11 11 Jan 2004 01:29 pm
Invisible Glass turbomangt The Detail Shop 3 19 Dec 2003 11:43 am
