Anyone have tutorial w/pics for door applique removal/install?
  • 1 Post By LionPT
Old 29 Aug 2015, 02:59 pm
thehoghunter's Avatar
Default Anyone have tutorial w/pics for door applique removal/install?
So, the instructions for removal of the door appliques was at
Door Applique according to many other threads...but that web site is no longer working (at least for me).
So I'm wondering what the trick is to remove the rear door front applique? On the rear door rear applique, the window is down and away from it, so no issue. The rear door front applique still has the window (in the down position) in the way. I ended up bending mine to get to the bottom torx screw and installed a new one without the bottom screw.
Anyone have a tutorial with pics?
2005 N/A 5 speed manual - Booger bushings, K&N Filter, MSD spark plug wires, APC Taillights, Accra-Form Running Boards, Hubcap Mike's Spoke Hubcaps, Retrosound radio (usb1-2/aux1-2/bluetooth), Chrysler 1949 Hood Ornament, and a Flameball white pearl shift knob (which makes it go faster).
Old 29 Aug 2015, 05:26 pm
rckstein's Avatar
Default Re: Anyone have tutorial w/pics for door applique removal/install?
You have to be very careful and with the glass all the way down, there is still enough room in the channel to push the glass one way or the other and you can still get your screwdriver on the screw. Before you remove the screw stuff a rag in the channel at the weatherstripping or you may lose the screw down inside the door. If this happens, then you have to remove the door panel to retrieve the screw.
Old 29 Aug 2015, 06:12 pm
LionPT's Avatar
Ahh, what the hell is a door applique..??
03TXPTGT likes this.
Old 29 Aug 2015, 06:18 pm
Handy_Cruiser's Avatar
I would just look here. I think there's plenty of videos showing how to install flame decals on cars.
https://www.google.com/?gws_rd=ssl#q...+decal&tbm=vid
Old 29 Aug 2015, 08:16 pm
rckstein's Avatar
They are easy to remove, follow these steps:
Originally Posted by rckstein View Post
To remove, you lower the glass and pull the glass weatherstripping out of the channel. In the weatherstripping channel there are some small torx head screws, remove those. Then on the inside of the doors, remove the torx screws at the end of the trim piece that is on the outside of the doors, at the bottom of the glass. On the rear doors there is a screw at each end and you can completely remove this trim piece from the door. On the front doors there is only one screw, at the back of the doors, not necessary to remove this trim from the doors, just remove the screw and loosen the trim piece. Then to remove the pillar trim pieces, from the lip that goes in the weatherstripping channel, gently lift up the trim piece and roll it towards the outer part that is rolled around the door edge. On the back of the trim pieces, at the top, there is a small plastic wedge that may be loose, don't lose those. Reinstall in reverse order. Also, when removing the trim screws, it helps to stuff a rag in the small crack at the bottom of the glass as you may drop some screws down inside the door, if that happens, then you have to remove the door panel to retrieve.
Originally Posted by bubba_1952 View Post
Handy, here are a few pics of how the pillars are mounted:
Old 29 Aug 2015, 08:21 pm
Is that what he's talking about? I thought he was trying to install a flame applique on the side of his PT.
Applique/Decal Kits. Install Time 1 hrs for CHRYSLER PT CRUISER. #82208550
Old 29 Aug 2015, 09:48 pm
03TXPTGT's Avatar
OP-
those are not appliques !
03TXPTGT
-2003 Chrysler PT Cruiser GT
-Patriot Blue, Bright Silver Metallic rear spoiler, billet grille, 17" chrome wheels, hyperground cable, Spectre short ram CAI
-119,000 miles and counting ...
Old 29 Aug 2015, 10:14 pm
rckstein's Avatar
Originally Posted by 03TXPTGT View Post
OP-
Sorry, but "applique" is part of the official name of this trim piece:
Item #2 in the below pic:
Chrysler PT Cruiser (2006-2010). #05288837AI: Door Applique
Chrysler 01 05 PT Cruiser Front Door Applique Left 5288837AF | eBay
Lift Gate Removal and Install rcalzadilla General PT Cruiser Discussions 1 14 Apr 2015 11:32 pm
LF door applique? red98gt General PT Cruiser Discussions 3 19 Jun 2014 05:29 pm
Passenger Front Axle Removal and Install Caustic Tech & Performance Forum 34 31 Aug 2013 01:06 pm
How to: 2007 stereo removal and dash speaker install. 2007 Sound and Security Forum 7 30 Dec 2008 01:57 am
Exterior Right Front Door Applique rszappa1 Exterior Accessories Forum 2 24 Aug 2004 04:55 pm
