help with universal power antenna wiring
Old 05 Oct 2015, 08:30 am
Default help with universal power antenna wiring
Hi,
This is my first post on this forum so forgive me if I do something wrong.
I have just purchased an universal power antenna for my 2001 PT cruiser and need a bit of help with the wiring.
I have mounted it to the wing and have also plugged the antenna cable into the adapter under the kick panel (which I read about in another thread) I just need help with the 2 power wires.
The antenna has 3 wires:
Red - I'm guessing is probably a constant 12v wire.
Green - again I'm guessing that its probably for when you switch the radio on.
Black - which I'm pretty sure is ground.
Here is a link to the antenna so you can see for youself:
Universal Car Electric Aerial Radio Automatic Booster Power Antenna w/Amount Kit | eBay
Any help would be appreciated.
Thanks
Old 05 Oct 2015, 08:56 am
Default Re: help with universal power antenna wiring
Because Trump
Old 05 Oct 2015, 10:03 am
Brilliant thanks for the response. Just tested the wires and found that the pink wire in the radio connector was a constant 12v and the red and white wire also in the radio connector was only hot when the ignition was on. but couldn't find a wire that was only hot when the radio was on.
Thanks for your help so far.
Old 05 Oct 2015, 05:41 pm
Because Trump
Tags
aerial, antenna, powered, radio, wiring
Universal Hidden FM Antenna Mast xwing777 Sound and Security Forum 3 24 Apr 2011 11:14 pm
Power antenna coopj40 Exterior & Interior Styling 9 20 Mar 2004 10:23 pm
Power Antenna MEGATON-PT Sound and Security Forum 3 27 Feb 2004 07:00 pm
Power Antenna kidturbofan Exterior Accessories Forum 7 09 Dec 2003 10:23 am
PT POWER ANTENNA ARPM Vendors & Buyers Forum 1 10 Apr 2002 03:49 pm
