Side mirror/case broke - easy to fix myself?
Like Tree2Likes
  • 1 Post By 03TXPTGT
  • 1 Post By dougs
Old 30 Dec 2015, 02:29 pm
Default Side mirror/case broke - easy to fix myself?
Howdy all,
I have a 2007 PT. I broke the driver's side mirror and outer case on a cement pillar.
I've checked out some YouTube and instructional things, and it seems easy, but I'm just wondering if there's any impediments that would stop me from replacing it myself.
I've replaced bulbs and stuff before, and it looks like I just have to remove the bolts and electric connector and reconnect, but I just wanted to make sure before I order that I wasn't overlooking some step that would foil me.
Also, any known places to order from would be appreciated recommendations!
Thanks, all!
Old 30 Dec 2015, 03:07 pm
03TXPTGT's Avatar
Default Re: Side mirror/case broke - easy to fix myself?
Originally Posted by Csd208 View Post
Howdy all,
Thanks, all!
I have my set off my 03 GT if you're interested in the set.
I think they should fit. Maybe someone can chime in and let us know.
PM me if you're interested.
Handy_Cruiser likes this.
03TXPTGT
-2003 Chrysler PT Cruiser GT
-Patriot Blue, Bright Silver Metallic rear spoiler, billet grille, 17" chrome wheels, hyperground cable, Spectre short ram CAI
-119,000 miles and counting ...
Old 30 Dec 2015, 03:58 pm
rckstein's Avatar
They are easy to replace. Remove the inside triangular trim piece and remove 3 nuts. You will also have to remove the interior door panel to unplug the mirror electrical wires. I have been told that a Gen1 mirrors won't fit a Gen2, but then others have said they will, but I have not seen this actually done.
Old 30 Dec 2015, 05:13 pm
Thanks for the info!
I was with you until I got to replacing the door panel, but none of the places around me have the piece in stock, so I guess I'll order the part and give it a go.
Thanks again!
Old 30 Dec 2015, 09:36 pm
Removing the door panel on these cars is very easy. Just a few screws to remove and then a couple of 10 mm bolts in the arm rest. Start in any corner and start gently pulling it out and pop the rest of the way loose. Pick it up and disconnect the wiring harness from the electric connector. Don't worry about removing the clip for the door handle. You won't need to.
Old 31 Dec 2015, 10:32 am
2step's Avatar
Here's a video "How To".......
The side mirrors should interchange for all years with the minor exception of some possible functional changes over time, such as heated mirrors, power adjust or the swing away deal. I don't recall if or what changes are possible, though, so just use your own common sense. I do recall that the convertible mirrors can't be switched with the hard tops because they are a different shape due to the doors and windshields being at a different angle....... I think???
Old 31 Dec 2015, 08:24 pm
Like I said, you DO NOT have to completely remove the panel. You can let it ride on the door linkage. It only takes a couple of seconds to undo the electrical collection for the mirror.
Old 05 Jan 2016, 02:47 am
dougs's Avatar
The mirrors are easy to take off, once you get over your fear of popping off the door panel. If I may say so, this would be a good time to think about sanding the plastic shells and painting them the matching body color...
rckstein likes this.
Black base 2006 NA, dented front bumper, scratched rear bumper. 2008 Touring, one of 385 red Turbos built in 2008. Limited grill, body-colored mirrors, grab handle deleted, dual-tone horn, shorty antenna.
Old 07 Apr 2016, 01:37 pm
bump... lol my mirrors on both side quit working? anyway to fix them? checked for blown fuse no luck? do they just go bad inside the mirrors? or could it be the switch?
Old 07 Apr 2016, 03:33 pm
Because Trump
03 PT GT passenger side mirror wtb larrybojac Classifieds: Want To Buy 3 01 Nov 2011 08:28 pm
Side Mirror jadmiral General PT Cruiser Discussions 5 05 Aug 2011 07:31 pm
Side Mirror Problem bjagd02 General PT Cruiser Discussions 0 01 Nov 2010 08:36 am
WTB: Mirror - Right side tipsymcstagger Classifieds: Want To Buy 2 10 Nov 2008 01:36 pm
Prismatic Side Mirror EJIII Exterior Accessories Forum 5 25 Jan 2004 09:53 pm
