Fog Light wiring
Like Tree9Likes
Old 03 Feb 2016, 12:20 pm
Arrow Fog Light wiring
So . I have a 2001 pt cruiser .. my fog light does not work... i took it to the garage to get it fixed , well i needed (for unkown reasons) the clutch replaced .. i asked them to take a look at the fog light, they did nothing .. i have recently checked and fuse 8 is not in place.. so i guess the previous owner removed it ,, so it maybe the MFS . i was wondering if i disconnect the corresponding cables from pin 12 13 and 14 (or something like this) and than put a fuse back and just connect the cabels together itt will work?? Without causing any further damege ?? Thanks
Old 03 Feb 2016, 12:40 pm
Handy_Cruiser's Avatar
Default Re: Fog Light wiring
In your other post, you mention being "at University" instead of "at college" and you use pascals rather than pounds per square inch. So I am assuming you do not live the US.
Based on a discussion in another recent thread, it appears that some non-US/Canadian PT Cruisers don't use Fuse #8 for the fog lights. Where do live and where is your PT from?
Old 03 Feb 2016, 03:15 pm
Wow what a knowledge there.. I'm impressed.. yes you are right. The car is from Europe (Central) from Chrysler Wien. As far as i can remember when i removed the cover on the inside it said fuse 8 and fog lamp or whatever .. though i'm not sure anymore.. tomorrow morning i will check it again
Thanks for your imediat and polite reply!!!!
rckstein likes this.
Old 03 Feb 2016, 03:24 pm
Vlefaive's Avatar
Try first your MFS ( Multi function Switch ) it's notoriously weak.
Easy switchout and cheap enough ( maybe 75$ US tops )
'03 GT Blue/ autostick.. 160,000KM ( That's 100,000miles for y'all South of the border ) All the options, the heated leather is a must up here in Canada, Love the solid heavy duty feel and obvious Torque.. The Turbo is strong, fast and reliable.. People that don't understand the love of a PT, probably don't deserve to.
Old 03 Feb 2016, 03:58 pm
Because Trump
Old 03 Feb 2016, 04:09 pm
Smile Re: Fog Light wiring
Yeah. I have seen your posts!! Nice job anyway .. Thanks i'll check it
Old 03 Feb 2016, 04:14 pm
Of course replacing it would be the most appropirate action I just can not understand that if it is the MFS than why on earth the previous owner did not replace it .. I mean a fog light is not something that i personnaly like to drive without in certain situations.. anyway Thanks for all of you i will check everything
Old 04 Feb 2016, 02:27 am
so ... today morning i have checked .. the indicator lamp on the dash comes on .. the orange one .. but none of the front fog lights come on.. though i haven't checked the back .. a question is that true that the front and rear fog lights has a different dash indicator ? just read than somewhere. I will defintely check now my user manual .. i really don't know why people are hating on that car .. everything seems to be well thought out not just tossed together as they say ..
UPDATE !!! the back fog lamp actually works .. so it cannot be the fuse than .. and i guess the MFS is right than .. but none of the front fog lights came on ..
last question and than i will stop my dumb questions .. if i dieceide to take apart the MFS, as the rear fog lights came on, for that i have to pull the end (it would activate the front ones .. as it does on the ones that has no rear fog lights) and than rotate that end part .. so i assume that for me aswell it is the pull ""thingy "" as well . so the question: if i attempt to repair it .. is there any chance that i could mess up something for ever ?? (as in one of the posts it said it could be done by anyone) THANK YOU
Old 30 Sep 2016, 07:49 am
Sinbad's Avatar
Another thread revival about Fogs - this time it's my rear fog I'm having trouble with...
I'm trying to connect 13 (fuse to MFS) to 12 (rear fog) but before I final wire the new switch in, I tried jumping accross 13 > 12 with a patch wire and got ....nothing
Checked the bulb and it's fine.
Checked contacts inside the connector and they are all fine (clean, and they show continuity back to the MFS plug)
I would have thought if I jumped 12 > 13, it should come on... ? or am I missing sumfin simple..?
(Sorry, should have said - it's a 2001 export into the EU)
Old 30 Sep 2016, 08:05 am
Sinbad's Avatar
To add: Wire 12 in my plug is brown/white - but there are TWO brown/white wires coming from that connector in the block.
Tags
fog, light, mfs
Need light switch wiring diagram for 06' PT notbobhope General PT Cruiser Discussions 6 05 Dec 2013 07:51 pm
Fog light wiring whitec1001 The Detail Shop 6 04 Mar 2013 03:12 pm
2003 Tail Light wiring bubbbab General PT Cruiser Discussions 3 07 Aug 2011 01:12 pm
Fog Light Wiring Harness...06-10 papawana Classifieds: For Sale/Trade 2 08 Sep 2010 02:03 pm
Fog Light Wiring h100250 Tech & Performance Forum 10 02 Nov 2009 06:03 pm
