Little rattling noise sounds like inside the muffler
Old 20 Feb 2016, 05:22 pm
Default Little rattling noise sounds like inside the muffler
Don't know if I got the right section or not but was wondering if someone could still help me out, I've been noticing that when the car is idling it just started making a little rattling noise by the muffler which sounds like it's on the inside of the muffler, because the shield on top of the muffler is tight I can't see anything else around the muffler area that is rattling. But it sounds like it's coming from the inside of the tail pipe end. I hope I explained it well enough. Was hoping that if what ever it is rattling if it is inside I hope it's not blocking the exhaust from coming out of the muffler. Thanks guys
Old 20 Feb 2016, 06:27 pm
Default Re: Little rattling noise sounds like inside the muffler
Try thumping on the muffler with your hand. Thumping on stuff is a good method to troubleshoot rattles. Mufflers have sheet metal baffles inside them, one may have broken loose. I wouldn't expect it to restrict flow.
Old 20 Feb 2016, 08:16 pm
If one of the sheet metal baffles inside did break loose does that mean we are in need of a new muffler?
Old 21 Feb 2016, 08:06 am
Not unless it just drives you nuts hearing it. Like Rick said, unless it creates a restriction in the exhaust, I wouldn't worry about it.
Mysterious Rattling Noise Gone Hoosier Tech & Performance Forum 16 25 Aug 2013 08:09 pm
Weird rattling noise and white smoke? mbaker115 Tech & Performance Forum 12 28 Aug 2012 07:27 pm
Front-end noise (sounds like I have a 4x4 truck) LTD7UP Tech & Performance Forum 18 03 Nov 2011 01:02 pm
Removed stock muffler PT Cruiser GT. It sounds great. dmkolb Turbo Performance 57 07 Jul 2010 09:10 am
sounds like wrist pin noise?????? Art Rigby Tech & Performance Forum 3 15 Dec 2009 05:34 pm
