Chrome edging - remove or ??
Like Tree29Likes
Old 14 Sep 2016, 09:16 pm
Question Chrome edging - remove or ??
I just bought a 2010 deep water blue PT Cruiser. Only 30K miles on it!
Just have a couple of questions about the chrome edges on this car, that go around the hood, doors, and hatch. Personally, I don't care for them as they don't "flow", they end in strange places, and just, well, I don't know. Not my thing.
They appear to be plastic. I have no idea what holds them on - friction, tape, glue?
Is anyone familiar with this type of trim? Would I be better off leaving them alone, or is it possible to remove them and get normal clean edges again?
Also, are the chrome spears likely to be stick-on aftermarket as well, or did 2010s come with chrome spears?
Old 14 Sep 2016, 09:32 pm
Default Re: Chrome edging - remove or ??
The edges are probably a "U" shaped with a sticky material on the inside of the "U" so when pressed onto the edge of the door both sides stick to hold it in place. The door spears are held on by 3M tape and it came with all the PT's but some had body color and some had crome depending on the trim level.
Old 14 Sep 2016, 09:54 pm
rckstein's Avatar
I think you should leave the door spears on, they really do dress up a PT.
The other trim you could likely take off pretty easily by applying a little heat with a heat gun to soften the adhesive, should pull right off and not cause any damage to the paint.
Old 14 Sep 2016, 10:47 pm
Handy_Cruiser's Avatar
I think all the 2010 PT's came with factory chrome spears and chrome grill accents. That edging around the doors and rear hatch is aftermarket and doesn't look that sporty to me. I'd remove and leave the spears.
Old 15 Sep 2016, 12:56 pm
Like above the edging has been added. The spears are actually OEM. You can tell by comparing the front door one where it meets the rear door. Compared to the paint ones. It has a different shape. The chrome covers are made to fit that shape of the painted ones. I personally like the spears. The rest can go.
Old 15 Sep 2016, 01:04 pm
Gkon's Avatar
If the chrome edging is fit around the edge of the doors, it's a U-shape, as CREWZIN mentioned, held on by 3M style tape. If they are laid flat on the doors, also held on with 3M tape.
You can likely peel them off or, as mentioned, some heat and then peel.
The spears look good! Don't touch them!!!
2002 PT Cruiser Limited, 2.4L, Automatic Transmission, Metallic Silver Paint
Old 15 Sep 2016, 01:22 pm
The edging clashes with the spears. The edged hatch look like a 1950s airliner?
Be carefull about removing them it could lift paint.
Factory installed, dealer or owner installed how do people know without the build sheet.
lol
Old 15 Sep 2016, 02:08 pm
rckstein's Avatar
You may be correct, see the link below to download the 2010 Dealer Brochure and is says: Molding, Bodyside, Chrome is standard.
But look at the last picture on the brochure, the PT doesn't have the chrome spears but does have a bodyside ground effects kit.
Auto-Brochures.com|Chrysler Car & Truck PDF Sales Brochure/Catalog/Flyer/Info 200 300 Aspen Crossfire Imperial New Yorker Newport Pacifica PT Cruiser Sebring and Town & Country
wwpptc likes this.
Old 15 Sep 2016, 02:56 pm
VsandFords's Avatar
Just Ditto to everything said.
Old 15 Sep 2016, 03:20 pm
Wow, thanks for all the replies! Sounds like we're all on the same page. I'm going to try to remove all the edging from the hood, doors and hatch, and leave the spears and grille alone. I think a little heat might be a good idea. I'll start slow. DO NOT WANT to lift any paint!
rckstein, Gkon and wingman55 like this.
How To Remove Front Seats & Remove Or Add Drawer Dill Interior Accessories Forum 20 16 Jul 2014 09:38 am
How to remove chrome solid bezel on solid antenna ptprice General PT Cruiser Discussions 6 01 Sep 2013 11:24 pm
chrome nuts, chrome nots, chrome disease sanatanadharma Interior Accessories Forum 2 31 Oct 2012 08:56 am
Chrome Door Edging on the Alteeza Tails BumperBob Exterior Accessories Forum 3 24 Jul 2005 01:40 pm
how-to remove chrome? Punch General PT Cruiser Discussions 10 08 Jan 2004 03:17 am
