06 Nov 2016, 03:19 pm
Re: Factory Body kit find>>>>>
Originally Posted by CREWZIN
I believe the ground effects package looks like this in case anyone is wondering...
It looks pretty cool, maybe on a show car, but not for practical use on a daily driver. I think they would get kind of beat up on the edges at the rear of the wheel openings as on the front wheel, the mud flap portion appears to have been removed, or the ground effect is applied over it, therefore, no longer providing any protection for debris picked up by the front tires, and kicked up against the rocker panel. And on the rear, you can no longer use the OEM mud flaps there. I also don't care for the look of the 3 caps, probably covering fasteners, at the top edge of the effect at the front of the front wheel. Also on the front you could be concerned with some damage that could be done when bottoming out, the stock air dam can get damaged, this maybe worse because it sticks down lower, would just have to be careful.
