PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
How to remove antenna bezel
Old 20 Jun 2004, 11:30 am
patbluecruiser patbluecruiser is offline
Default How to remove antenna bezel
Hello:
I bought a chrome plated plastic antenna bezel, but can not figure out how to remove the OEM one. I took off the antenna. Is the chrome piece that the antenna screws into a "nut"? You just unscrew it? It has three grooves in it. Do I just get a screw drive and they to loosen it?
I used the search feature but the only link I found that was helpful sent me to ptdoityourself.com and do not have a membership.
Thanks,
Andy
Old 20 Jun 2004, 12:33 pm
pt_from_ct pt_from_ct is offline
I used a screw driver and a hammer..( Tap lightly ) then once i had it loose enough i used needle nose pliers. Just go easy with the screw driver. I have done many this way and never had a problem.
http://ptcw.truckmoxie.com/mygallery.ten?id=3466
Old 20 Jun 2004, 12:41 pm
gonzomania's Avatar
gonzomania gonzomania is offline
Send a message via AIM to gonzomania
Don't unscrew antenna. After the nut is unscrewed lift nut and bezel off antenna this way lower section doesn't fall into wheel well. Install bezel and nut while holding antenna tighten as needed.[8)]
Gonz
Old 20 Jun 2004, 02:12 pm
Jimbo Jimbo is offline
If you open the door you can see the antanna lead.
I used needle nose plyers in the grooves of the nut to
get it off.Once that nut is removed the bazel comes off
easy.
04 cool vanila Limited Turbo
Wife has a 03 limited
(Steel Blue)
Old 21 Jun 2004, 01:26 pm
Thanks guys...
It worked like a charm. Now I dont have the "waxy" plastic bezel anymore.
Thanks agian,
Andy
2003 Patriot Blue PT Cruiser
2005 Show Schedule
Cruisers @ Daytona IV - May 6,7,8
Cruise the Alley IV - May 20, 21
Meet Me in St. Louis on Route 66 - July 22-24
Many local shows!
Old 22 Jun 2004, 08:43 pm
josheypt josheypt is offline
Send a message via AIM to josheypt
what works even better then a flat head or needle nose is using snap ring pliers works PERFECT! that is how i took mine off when i shaved my antenna
joshey
http://www.trialclix.com/index.asp?refID=114683 i already got an ipod for free check it out
vB code is On
question on installing chrome antenna bezel comPuTer General PT Cruiser Discussions 21 27 Jul 2006 04:26 pm
Antenna Bezel Replacement Chip Exterior Accessories Forum 3 08 Jan 2006 01:53 pm
Chrome antenna bezel rszappa1 Exterior Accessories Forum 2 24 Aug 2005 07:24 pm
Chrome Antenna Bezel Gunner Exterior & Interior Styling 4 14 Jul 2004 12:20 am
antenna bezel Noah1915 Exterior Accessories Forum 9 16 Oct 2003 02:52 am
  Millberry posts | Flights | Loans | Coin Community | Car Insurance
