Driver's Side Window Problem
  #11 (permalink)
Old 22 Dec 2016, 02:54 pm
Default Re: Driver's Side Window Problem
I'm still holding off for now. I went to the dealer and they want $95 plus tax. Also, they give you the bull line that's for starts and if it doesn't work then it could be more. Not being able to be present as they perform the reset, I really don't trust them and feel they will come across they had to do something else as well. Now we all know that if everything was working perfectly fine and the problem only happened (immediately) after then battery cable was reconnected after being disconnected for 6 months, they can be no other reason.
  #12 (permalink)
Old 10 Mar 2017, 05:25 pm
I finally brought it to the dealer. Crazy, they said they couldn't reset it after several attempts. Now they're saying I have to replace the regulator! Really, the windows work fine; the only problem is the driver's side window doesn't work with smart-glass. The passenger side works fine. Open the door, it drops about a quarter of inch and goes back up when the door is closed. I thought it was odd, and they're 'fishing" to find the problem. The regulator, and installation is around $700....OUCH
  #13 (permalink)
Old 13 Mar 2017, 09:37 am
Fk5 Fk5 is offline
Not taking the side of the dealer, but I have had cars where the problem was the regulator and the windows worked fine except for that last 1/4". I think the teeth wear out on the end causing the problem. I have no idea how this will relate to yours because those cars were manual window cars from the '70s. You could look into doing it yourself. I'm sure it would be cheaper, but I don't know how much or or how easy it would be.
Someone here must have done it. I have done a bunch on 2.2 mopars, but those were just plastic tracks that had to be replaced.
2003 GT 5 speed
150,000 miles
  #14 (permalink)
Old 03 Oct 2017, 04:37 pm
Really curious of the outcome on this post! Iím now having the exact same dilemma! Iíve tried everything up to this point recommended! Did you take yours in and what was the result if thereís any other info out there!! Thank you!
HELP! DRIVER'S SIDE WINDOW WON'T GO UP golddust General PT Cruiser Discussions 9 30 Mar 2017 09:05 am
2007 PT driver side front window gets stuck. Majestyk2k Western PT Forum 3 23 Aug 2016 07:57 pm
Problem with driver side window evonna_21 General PT Cruiser Discussions 5 19 Dec 2015 02:06 pm
Driver Side Window Problems...ANNOYING Cathy06PT PT Cruiser Convertible Forum 8 02 Dec 2015 07:15 pm
Front Driver Side Power Window Stopped Working itsjusme Tech & Performance Forum 4 08 Dec 2014 01:24 pm
