Red VHT Niteshades over blinker
Like Tree2Likes
  • 1 Post By Odin
  • 1 Post By Busted_PT
Old 18 Mar 2017, 04:32 pm
Odin's Avatar
Default Red VHT Niteshades over blinker
I've never liked the white area in the taillight. I also don't like aftermarket options enough to spend money on them. I don't care for euro or altezza style lights, or the ones that have sections that protrude further than stocks. So I decided to try out the red VHT Niteshades. The black VHT looks good, but I have been behind a number of vehicles with it and it makes the brake lights very difficult to see. I ended up using 5 very light coats, with 2 coats of clear, and I think it looks really good.
rcktpwrd likes this.
07 Touring Edition 2.4 NA
Old 18 Mar 2017, 04:42 pm
Default Re: Red VHT Niteshades over blinker
I tried it but did not like the results. Either it was uneven for thickness and when you applied the brakes look odd or as you said was just to dark.
I chalked it up to nice idea but not user friendly.
I did my bumper lights and posted the pictures on the forum but cant find them....ROB HELP!
Old 18 Mar 2017, 04:46 pm
Hopefully you didn't spray over the reflector on the side of the light. That's a mandatory requirement in ALL states so the car can be seen at night with the lights off. The reflective "red" shows where the tail section is and the "amber" reflective surface inside the headlight shows where the front of the car is. If your state doesn't have an inspection, there's not too much to worry about.
Old 18 Mar 2017, 06:20 pm
The reflector is inside the housing. This is a transparent paint. So the reflector will still reflect through the red.
Nitro you bring up a good point in using transparent paints. To avoid striping. It should be sprayed with a 75% overlap. I plan on one light tack coat. The two wet coats using the 75% overlap. I may mask off the yellow part and color that first and a final coat over all to keep from getting to dark. Then clearcoat. I love the all red on the Red PT.
Odin likes this.
Old 18 Mar 2017, 06:37 pm
Odin's Avatar
If I did it again I would mask the red area and put a couple coats on the white part, then remove the mask and put a couple more over the whole light as there is a slight difference in color between the two sections. I used to paint giant sculptures and ride cars for the theme parks in Florida, so I didn't have any issues with streaking. The 75% overlap is always a good rule of thumb with kandys and the like.
Old 18 Mar 2017, 06:38 pm
On the PT Cruiser forum that is now gone there was thread which JoeCruiser (I think) and one other member and myself posted and talked about using the VHT Niteshade paint. If you recall you and I had a conversation about how bad this paint was on the tail lights?
I found the bumper lights I painted but sanded off the paint.
Old 18 Mar 2017, 06:58 pm
Ya, I remember that. I'm useind a automotive candy in a spay can. So I expect to lay nice without splotch. That may be another option for you. I'm sure you can get anything mixed in a spray can. Somebody kindly sent me mine. I brought this up for those considering doing theirs. I know you are as good with a spray can as I aim. And can make it look as good as it can be done my friend. I'm also going to use that high impact clear from Tamco on mine. So the finish will be as hard as it gets to damage it.
Blinker short? tedleo General PT Cruiser Discussions 0 19 Nov 2010 04:42 pm
Another multifunction blinker issue tedleo Tech & Performance Forum 3 28 Jul 2010 06:29 pm
steering wheel - not canceling blinker? BuckeyeMark Tech & Performance Forum 2 03 Mar 2009 03:40 pm
can't see blinker flashing - steering wheel Curruzr General PT Cruiser Discussions 13 09 Dec 2004 03:00 pm
