Adding Fog lights quick Question
Like Tree15Likes
Old 19 Mar 2017, 11:12 am
Default Adding Fog lights quick Question
Ok, I have an 05' Base. I have purchased and received the OEM fog light option kit with MFS, lights, and harness. My PT already has fog bulb sockets wired, where will I find the other ends to tie the new harness to? Is it already run through the fire wall or is there a leg sticking out somewhere near the Power Distribution block? Hoping to get this done today thank you!
Old 19 Mar 2017, 05:42 pm
Default Re: Adding Fog lights quick Question
I think it's fuse 11 - anyway, the cover to the fuse block should say "fog lts" or such and I think it's 10A? (again, it's on the cover).
If you have the sockets there, the rest ought to be in place to plug into.
You ought to find a hanging connector near the Multifunction switch and you should just have to plug in a fuse.
Old 19 Mar 2017, 09:11 pm
Nope no wires in #8 of the interior Fuse block however my kit came with the jumper and all wires to complete. It appears that they "Chrysler" only included the sockets, and the wires disappear into the rest of the harness. I did not get a chance to dig that much today.
Here is the kit I got:
Old 19 Mar 2017, 09:20 pm
Link to PDF instructions for installing a MOPAR PT Cruiser fog light kit
Fuse #8 (15 amp) in the dash fuse block
Old 20 Mar 2017, 12:27 am
Originally Posted by sanatanadharma View Post
Thank you, however I have the instructions. I guess I need to clarify the question I am asking. I am trying to avoid running the entire new harness by tying into the existing harness that apparently was partially ran during manufacturing. My 2005 Base already has fog light sockets provided, I am just wondering where chrysler hid the other end...
Old 20 Mar 2017, 06:30 am
ptprice's Avatar
sanatanadharma, ya beat me to the punch. I always bow to the fog light gurru. I'd found the same info and was gonna post it this AM.
evoscouter has a break in his existing line. That he has an existing fog light circuit is evident 'cause of the fog light sockets. It was probably cheaper for Chrysler to use the same wires on each PT than not. With the trace info you've give him he ought to be able to back track his fog light circuit to a break. That's not gonna be easy but it can be done. You gave him a good visual. I check for a break in a wire loom by wrestlin' the sheathing aside and putting a pin through the right color wire to test for a break in current along the line using either the continuity or voltage feature on my electric tester.
If not he could return that beautiful MFS switch and go your route of a secondary switch. I'd fix the break or splice onto it at that point and use that dedicated MFS switch with the fog light switch embedded. Perhaps his old MFS switch'll work with the break in the wire corrected.
Happy PTin', ptprice
SOOO BIG 2005 PT CRUISER, LIMITED EDITION, SIGNATURE SERIES
Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. PT Chrome Clad 16" X 6" Wheels, P205/55 R16 Cooper Starfire/Solarus tires, Touring Suspension. Chrome Package; Side Spears, Grills, Fuel Filler Door, Door Locks, Handles, PRND3-1 Bezel, Silver/Chrome Shift Ball/Knob, Bright Spoke Leather Tilt Steering Wheel. Chrome Tail Lights, 3/8" Belt Trim. Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry, Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Under Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers, Back up Camera/ 7" Monitor.
Old 20 Mar 2017, 07:57 am
I built my fog light circuit on my 05 base myself instead of using the kit, and I could not find the location of where the power and ground from the bulbs ended in the engine bay. I do know that they are connected to ground, and the power wires are connected to each other. All you need is a power wire spliced into the power side of the pre-existing connectors. Then all the fun stuff under the dash that the Mopar kit should make super easy.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 20 Mar 2017, 02:46 pm
These are the places to look for existing wiring and connectors.
Starting at the multi-function switch connector, look for wires at pin's #13 (pink/light green) & 14 (light blue).
The pink/light green wire goes to fuse #8 (15 amp) in the dash fuse block.
Of the two light blue wires at pin #14, one goes to the instrument cluster idiot-lite; the other goes to the grey connector C106 behind/ below the fuse block, (26 pin connector).
From the other half of this connector, the light blue wire circuit goes through the firewall to the front fog-lamp connectors.
Fuse #8 is feed by a tan/black wire connected to pin #A4 at the headlight relay (on the fuse block).
Power to this relay is via a light blue/orange wire at pin #A5; it is spliced to the circuit out of the dash fuse block, fuse #1 (25 amps); also light blue/orange.
ptprice likes this.
Old 20 Mar 2017, 06:02 pm
ptprice's Avatar
It's a real simple test if it's compatible with a 2007. This worked for me as I tested SOOO BIG's wiring but SOOO BIG's a 2005. Before you do it, Check to see if this is all right with our guru sanatanadharma 'cause the 2007 might be different that a 2005 like SOOO BIG.
Pull the 20-way Headlamp Switch connector in the back of your MFS switch. Then you can do a jump test of the fog light curcuit's completeness. Just jump # 13 and #14 and the fog lights should go on. With that power feed you can trace your wires to the break in the line. This should only work if your hooked to the fusing.
Happy Ptin', ptprice
Old 20 Mar 2017, 09:58 pm
I appreciate all the idea's everyone. I guess I will just check for continuity by plugging a long wire into the positive on the fog light socket and poke wires with corresponding colors. As I said before it is an 05 base that never had fog lights installed. So with that said there is no wires at the 13,14 position of the 20 pin MFS plug. Also there are no wires going to Fuse 8 in the fuse block. I am hoping to find that chrysler conveniently brought the fog plug wire/wires all the way into the car.
Once I track them down I will post where they are located, I know I am not the only owner who has the plugs for fog lights and nothing else.
Gkon likes this.
Adding Fog Lights, wired to headlights PTLUCKY Tech & Performance Forum 4 17 Oct 2015 09:02 am
Quick question regarding gauge lights 2008ptcruzrtouring General PT Cruiser Discussions 1 29 Mar 2015 11:36 pm
adding fog lights right now need help!!! maverick General PT Cruiser Discussions 12 02 Mar 2014 03:54 am
Info on adding rear fog lights BMotter Exterior Accessories Forum 13 20 Oct 2013 06:51 am
Adding Cruise Control and Fog Lights VNT Tech & Performance Forum 2 17 Apr 2011 03:49 pm
