Antenna bezel/replacing it
Old 18 Jul 2017, 01:35 pm
Default Antenna bezel/replacing it
Hi to all!
Get finally off my broken antenna (telescope)
and its a big hole without that bezel. Anybody but some universal antenna fo old bezel?
other option is buy new on from a dealer (big moneyi guess)
Try googling around but nothing, maybe i dont know exact words for this..
Old 18 Jul 2017, 01:53 pm
thehoghunter's Avatar
Default Re: Antenna bezel/replacing it
antenna parts
Take a look at the link...you may have to change the year of your PT.
2005 N/A 5 speed manual - Booger bushings, K&N Filter, MSD spark plug wires, APC Taillights, Accra-Form Running Boards, Hubcap Mike's Spoke Hubcaps, Retrosound radio (usb1-2/aux1-2/bluetooth), Chrysler 1949 Hood Ornament, and a Flameball white pearl shift knob (which makes it go faster).
Old 18 Jul 2017, 03:41 pm
here is "same" link with my model year.
https://www.moparpartsgiant.com/part...s-antenna.html
Seems that part number 5 is not available anymoore
and my is bit different, it has telescope which cannot be removed from part number 5 unless you dont broke it.
So is there any aftermarket options which should of course cover the all of the hole?
Old 18 Jul 2017, 03:53 pm
rckstein's Avatar
If you have a telescoping antenna, then that is most likely an after-market that was added.
Here's a link to the fixed mast base on Ebay:
Genuine Chrysler PT Cruiser Antenna Cable 4671626AD | eBay
Old 18 Jul 2017, 04:05 pm
i dont think that is aftermarket. i can check that later..(it is import car made for european market, we use FM not AM )
so it seems that i have to buy new one.
i understand that later model year will fit if chance the base too (what i have to do anyways)
i was hoping that there were nicer solution of aftermarket antennas
(maybe shorter/chromed etc)
Old 18 Jul 2017, 04:09 pm
rckstein's Avatar
If I were you, I would call a dealership and give them the VIN to your PT, they will use that and give you the correct and current part number for the item you need, then you can use that part number to search the internet.
Old 18 Jul 2017, 04:13 pm
i can do that when my vacation ends
i just got that feeling that they dont made them anymoore, just dont remember how to get a replacement one/ repair old using some new parts
i'll do searching and made changes and let you know if here are european users more
Old 19 Jul 2017, 03:18 pm
rckstein's Avatar
Today in another thread a member posted the Build Sheet for his PT. It was an export like yours and I noticed on the Build Sheet it has Manual Retractable Antenna.
I used his VIN and went by my local dealership to get the MOPAR part numbers for you. This is what they have in their system:
It has the part numbers, but the collapsible antenna is no longer available and I found some websites that has it listed and a price, however, I suspect that if you try to order it they will come back and say that it's no longer available. So you might try a salvage yard for a replacement, or as the MOPAR parts catalog has is you replace it with the fixed base and mast, like all the US PT's have.
But one would have to wonder that if they went to the trouble of putting in a manually retractable antenna on the exports, why didn't they make it a power antenna?
Antenna bezel bubba_1952 Classifieds: Want To Buy 5 15 Sep 2014 10:48 am
Antenna Bezel ucantcme Exterior Accessories Forum 23 14 Oct 2008 04:56 pm
Antenna bezel Franksredpt Classifieds: For Sale/Trade 0 02 May 2008 08:07 pm
WTB: Antenna and antenna base with bezel thegoldpt Classifieds: Want To Buy 1 03 Dec 2007 09:21 am
antenna bezel Noah1915 Exterior Accessories Forum 9 16 Oct 2003 02:52 am
