Another Electrical Question - Rapid Flashing signals
Like Tree4Likes
  • 2 Post By Sinbad
  • 1 Post By rckstein
  • 1 Post By soonercruiser
Old 10 Nov 2018, 12:00 am
soonercruiser's Avatar
Lightbulb Another Electrical Question - Rapid Flashing signals
Converted all the tail light bulbs to LEDs on the Panel Van Project.
The turn signals are blinking very rapidly, almost like when there is a short in a bulb.
But, all the bulbs are working fine.
** And, the hazard flasher are flashing at the normal rate.
I've never had a problem with conversion to LEDs before.
Thoughts???
Frank, aka SOONERCRUISER,
Old 10 Nov 2018, 01:39 am
Sinbad's Avatar
Default Re: Another Electrical Question - Rapid Flashing signals
You need LED's with resistors - the car thinks you have a bulb gone because the LED doesn't register as drawing current. Ergo, it blinks rapidly to warn you.
Quite honestly I'd put the old standard indicators back in and forget it - LED's will save you power draw when you use them for main lighting but for indicators they aren't worth the aggravation.
rckstein and Alfie1 like this.
_________________________________________
'07 2.2 CRD
Old 10 Nov 2018, 07:44 am
rckstein's Avatar
When I was researching the hyper-flashing when I switched to LED Sweeplites for the rear turn signals, I came across a post somewhere where that person was able to fix their hyper-flash issue on a Gen1 PT by replacing the turn signal flasher. The Gen1 has a replaceable turn signal flasher where the Gen2 it's built into the instrument cluster.
I happen to come across this flasher module for the Gen1:
https://www.diodedynamics.com/led-fl...t-cruiser.html
https://www.amazon.com/2001-2005-Chr.../dp/B00KQV1606
soonercruiser likes this.
Old 10 Nov 2018, 07:43 pm
Thumbs up Re: Another Electrical Question - Rapid Flashing signals
Thanks Rocky!
I knew someone would have the easy fix!
I found a new one on eBay for $16.79......
rckstein likes this.
Dead Electrical Question genther General PT Cruiser Discussions 10 14 Nov 2014 05:21 pm
Rapid clicking from starter won't start joebullits General PT Cruiser Discussions 6 24 Aug 2012 07:09 pm
03 gt electrical question jacarc1 General Turbo Discussions 3 27 Mar 2010 06:19 pm
electrical system question Thrusst Turbo Performance 1 09 Aug 2007 06:52 am
Bye Bye Rapid Craft CREWZIN Vendors & Buyers Forum 1 31 Jul 2003 12:02 am
