Relocating the radio antenna
Like Tree14Likes
Old 07 Oct 2020, 04:39 pm
soonercruiser's Avatar
Default Relocating the radio antenna - FINAL UPDATE!!!
SKIP TO POST #15, FOR THE BOTTOM LINE!
Because of the peeling quick job painting the panel Cruiser, I am going to have the Cruiser repainted next week.....a special paint scheme. Some of the clear already oxidizing too.
But, since I have shaved door handle already on the rear doors, IT'S AN OPPORTUNITY TO ELIMINATE THE RADIO MAST!
What would I do to eliminate it.
My DIY self says simply run a long replacement wire along the windshield inside or outside.
That would also allow me to shave that hole in the fender.
WHO HAS ALREADY DONE THIS?
Frank, aka SOONERCRUISER,
Old 07 Oct 2020, 07:35 pm
rcktpwrd's Avatar
Cool Re: Relocating the radio antenna
I was looking at something like this for the wife's pickup:
Stealth Antenna
no idea how good or bad they work.
Joel
www.rcktpwrd.com
Old 07 Oct 2020, 11:15 pm
Default Re: Relocating the radio antenna
To me...the antenna is nothing more than an enclosed wire; wires wound around a stick; or a mast.
So, I don't think that you need to buy something like that.
I noticed today, that even though the windshield sealer has the bottom edges of the windshield seal pretty tight....
There is some lifting room above the seal to accommodate a thin wire.
I remember that my old Sansui receiver had nothing more than a plasticized wired to attach as the indoor antenna.
Thought that I could do that! Maybe evn hide under the edge of the head liner.
I just thought someone here had done it already.
Or, had some expertise on the wire requirements for AM/FM radios.
Old 08 Oct 2020, 05:49 am
Handy_Cruiser's Avatar
Back when I had my red 2001 Limited, I did some experiments with radio antennas. What I found was that the height of the PT's cabin kind of blocks radio signals. So while short antennas worked fine in central Arkansas near the major radio towers, I would always start losing signal when about 50 miles away. I tried several things to prevent this. An old stereo signal booster from the 1980's seemed to work best. But nothing fixed the problem other than returning to a long antenna. The PT convertible doesn't have the issue since it doesn't have that big metal roof line. It should also be noted that Arkansas has a long history of very powerful radio stations. With most of the state being rural and half of it being mountainous, those towers are very big and most are located on mountain tops right outside of Little Rock.
I'm going to be interested to see how well a stealth antenna works when 50 miles or more away from the radio towers. It's possible that one mounted in the right place will not have the problems I had.
PS: I reallly like that paint scheme in the photo above. That would be very cool.
Old 08 Oct 2020, 11:50 am
We are about the same signal situation here, with many strong radio stations in the metro OKCity area.
I am currently using an aftermarket antenna about the same length as the OEM antenna, and have no problems with signals towards Tulsa and the Texas border when on short trips.
If I am able to mount a wire up high, under the edge of the windshield seal, or inside under the edge of the head liner, I am sure that it will be as good as what I am currently using anyway.
Handy_Cruiser likes this.
Old 11 Oct 2020, 05:10 am
I have ordered a hidden antenna, and signal booster.
Where can I pick up a hot 12V line for the signal booster?
I really don't want to tie into the radio itself.
I'm sure there is a hot line up the passenger side window pillar.
WHAT COLOR WIRE IS IT???
Old 13 Oct 2020, 03:45 pm
For wires near the radio, there are the two power outlets, one switched and one always on - Adding power accessory plug to base model
Old 13 Oct 2020, 06:30 pm
Thanks Pal!
Old 20 Nov 2020, 12:55 am
How's the installation and performance of that antenna?
Old 20 Nov 2020, 06:03 pm
No there yet!
The Cruiser has been in the paint shop 4+ weeks now.
And, I believe that they want to take Thanksgiving week off.
I am not going to put on any pressure; as they are doing an awesome job, and removing parts to paint that I thought they did not need to.
I dropped off a modified Chrysler wing emblem for the one they broke taking it off the rear hatch yesterday.
Carl had it all covered, ready for the bottom gray metallic spray today.
But he peeled back some of the plastic to show me how David had wet sanded and buffed the blue above the beltline....and it is like glass!!!!
So, I'm not likely to be getting a chance to do those things like the antenna until the week after Thanksgiving.
raeder likes this.
How to replace radio antenna on PT Cruiser Gigie General PT Cruiser Discussions 10 29 Dec 2014 02:58 pm
Replacement of OEM Radio Antenna MrCorvette Sound and Security Forum 2 08 Jun 2014 06:54 pm
Radio antenna cable ran inside the car... mstyler05 Sound and Security Forum 7 22 Mar 2011 10:51 am
XM Radio Antenna upser14 Sound and Security Forum 8 14 May 2009 10:02 pm
Antenna removal from Radio therents Interior Accessories Forum 7 10 Jun 2004 10:23 pm
