Driving/Fog Lamps
Old 04 Aug 2004, 06:30 pm
Default Driving/Fog Lamps
I'm thinking about adding an extra set of lights, what's on the PT currently works well, but I go down pretty dark roads at night and want to be able to see what's out there a bit sooner. Would mounting a set of driving lights (Hella, PIAA, KC) to the bottom of the front bumper between the fog lamps be the way to go? I really don't want to spend $600+ on HID. Will they "reach" beyond the high beams? How difficult are they to wire up?
Old 04 Aug 2004, 06:38 pm
Can't really answer about how far they reach but i do know that if I attached anything to the bottom of the front bumper, it'd be gone into a thousand pieces before the week was up. You're talkin pretty low down there. For high intensity driving lights to work well, they should be mounted a lot higher than that.
Old 05 Aug 2004, 08:02 am
Go to a good auto store and look at what they have - I've seen some the diameter of a coffee cup - don't know how much light they put out, but I bet if you stick with a good name, like Hella or PIAA, you should be okay. There would be enough room for those on either side of the grille - you could either mount to top or bottom of bumper or have a bracket from behind grille. Wiring would be easier there - in-line fuse on + to battery, - side to switch. Be sure to use heavy enough wire - depending on wattage, I'd go #12 or even #10 (can't be too heavy, only too thin). For switch, easiest is go thru hole in firewall that existing wire harness uses by steering wheel and put switch by "trap-door" fuse panel. (that's where my wiper LED lights switch is). You could also put in a relay so you only have to wire switch with smaller wire.
Old 05 Aug 2004, 09:25 am
gonzomania's Avatar
Send a message via AIM to gonzomania
Try this post on this forum Post Pics of Fog Lights in search. There is a picture on page 3. Hope this helps
Gonz
Old 05 Aug 2004, 11:17 am
http://www.ptcruiserlinks.com/forum/...rms=fog,lights
Old 05 Aug 2004, 11:49 am
gonzomania's Avatar
Thanks QSD
Gonz
Old 05 Aug 2004, 08:12 pm
Chromedcruiser--If you have the factory fog lamps, I'd recommend replacing the stock bulbs with Sylvania Silverstars. They are alot brighter than stock but to my knowledge have the same wattage rating so your electrical system isn't working any harder. I really like mine. The Sylvania website lists the wattage as 60 maximum and a life expectancy of about one year which kind of surprises me. I thought they would be expected to last longer. Maybe mine will.
[IMG]|2003 PT GT 5-Speed | Mopar Stage 1 | Mopar 2.5\" Dual Exhaust | Mopar Short-Throw Shifter | Mopar HO Plastic Intake | Mopar Boost Gauge | AGP WGA/BOP | APC Carbon Fiber Taillights | Axis 19x8 Wheels/Yokohama 225/35ZR19 Parada Spec2 Tires | BTG Strut Tower Brace | BTG Billet Shorty Antenna | Eibach Anti-Sway Bars | HKS SSQV BOV | JLM Motor/Tranny Mounts | KW Variant 1 Coilovers | Maxxfab 3\" Downpipe | NGK Iridiums | Prototypepower UCP/CAI v5 | PTeazer Smoothie Roll Pan | Screamin\' Demon Coil/Livewires | StopTech Slotted Rotors/Hawk HPS Pads/Stainless Steel Lines | Unorthodox Racing Underdrive Pulley|
Old 07 Aug 2004, 10:05 pm
Old 07 Aug 2004, 10:07 pm
CHROMECRUISER
I added a set of small square Hella Driving Lights between the grill and the radiator. Don,t remembert the model but they are about 3x2x2. Wired thru relay with switch dirrect to battery and dash.
axelrod
Old 08 Aug 2004, 03:39 pm
Send a message via AIM to bigtommy83
quote:The Sylvania website lists the wattage as 60 maximum and a life expectancy of about one year which kind of surprises me. I thought they would be expected to last longer. Maybe mine will.
I think that means they can be left on for a year, or a total time they can be left on equals about a year. There are 8760 hours in a year, you maybe drive an hour or two a day, maybe less with your lights on, so they will last about from 4380 to 8760 days or maybe 12 years...
\'04 GT 5-speed, Brand X, Air Force One Intake, Custom Flowmaster Exhaust (retired), SRT-4 exhaust no resonators, AGP Wastegate, Crusher Kit, Former Chrome Package, Mopar BOV, Custom Sub Box, Mopar Pillar Gauges, Hood Scoop, MBC, Stage 1, Mopar Stage 1 Springs, Hurst STS
Future Plans: Custom Intercooler Sprayer, 2-tone Paint Job
\"Hondas are like cigarettes, everyone cool smokes them\"
Fog Lamps? thegoldpt General PT Cruiser Discussions 8 07 Nov 2005 02:22 am
WANTED stock fog lamps tangerinedream1845 Classifieds: Want To Buy 0 27 Feb 2005 05:18 pm
Fog Lamps Kit Problems--->Fix It 340x Tech & Performance Forum 3 04 Jan 2005 10:54 am
Humidity in tail lamps, no waranty?? Ian-PT-GT Exterior Accessories Forum 10 31 Mar 2004 12:38 am
prejector lamps ptgt Exterior & Interior Styling 4 05 Aug 2003 11:40 am
