LED washer longevity
Old 06 Jan 2005, 05:14 pm
Default LED washer longevity
This morning, I noticed one of my LED washer lights was out - a chance it's the wiring, but my first guess is it died - this is already my second set - shouldn't they last? They're cheap enough, but removing those damn hood blanket pins is such a hassle...
Just ranting...[xx(]
Old 06 Jan 2005, 06:00 pm
Don,
After I put the polshed stainless steel under the hood, I certinally didn't want to have to take that down if the washer lights went out, so I connected the hot wire from the lights (ground wire would work also)to an in-line on/off switch and now only use the washer lights at shows and events where I want to show them off not every time I turn the headlights on.
Old 07 Jan 2005, 08:38 am
I have mine on a switch (ground) but use them nearly all the time. I thought one of the main advantages of LEDs (aside from less heat) is that they last way longer than bulbs with no filament to burn out...[:I]
Old 07 Jan 2005, 10:22 am
10,000 hours, no heat 100% of the energy is converted to light, vibration resistant,should not burn out.
maybe they dont like the cold either?
Old 11 Jan 2005, 08:29 am
Finally got to checking the wiring - it seemed okay, tried them again - I noticed the "bad" one wasn't dead, but very dim. It was lighting, but at about 25% the intensity of the other one. ?????
For now, I may throw a resistor inline with the bright one so at least they look the same 'till I get a new pair.
Easy to replace - except for that damn hood blanket with those pins [xx(]
Old 13 Jan 2005, 05:02 am
LED's typically only dim if the voltage to them is reduced or the lens is dirty. You likely have excessive resistance in one of the wires frequently a bad ground) if it comes on at all.
Old 13 Jan 2005, 08:37 am
I'll check again, but I have both hot and ground wires from the 2 lights paired. It's not the lens.
Pressure washer Mr.Barton The Detail Shop 7 27 Oct 2004 09:19 pm
Washer Nozzles SRG General PT Cruiser Discussions 2 02 May 2004 11:25 am
relocate windshield washer rnbenoit Exterior Accessories Forum 6 03 Aug 2003 11:22 pm
LED Windshield Washer Lights Jerry Exterior Accessories Forum 2 29 Sep 2002 01:59 pm
Washer fluid ssbandit19 General PT Cruiser Discussions 1 27 Sep 2002 03:20 am
