Hookin' up LED's
Old 26 Jan 2005, 02:13 pm
Default Hookin' up LED's
Hey ya'll,
[:I]
Before I crawl under my 2003 PT Ltd Ed, can any of you tell me just exactly where you found a spot to fish the wiring through to the interior of the car? I bought a green LED kit, legal in Ohio, so it seems, and I plan on installing them myself, if I can, without too much drilling and cuttin!
Thanks
Old 26 Jan 2005, 02:33 pm
When I installed my girlfriend's LEDs, I ran the wiring through the steering column boots. There is an inner and outer, and they are big enough to be able to slip back in place with the wires under the edge. We live in So. Cal., with nice weather. It may not be the best solution for North Dakota. If you have an Auto, it might be better to remove the clutch block-off plate and drill a hole. The wires must be tied up very well, and make sure the areas where people may use a jack or hoist are clear.
Old 26 Jan 2005, 07:26 pm
SmittysPT's Avatar
If its a auto trans, there is a plug where the clutch rod would have run throught the firewall. Works well....
Old 26 Jan 2005, 09:58 pm
2step's Avatar
Some have reported back that they used the gromet that the hood release goes through. There is room for a wire or two to get through.
Old 27 Jan 2005, 12:21 am
Thanks, that'll give me some options to look for.
It is an automatic, so hopefully I can find that plug for the clutch. Should be in a nice spot! I hope it's big enough, the plug is flat and about an inch wide on the end of the cable. If I have to, I can cut the cable and splice it back together on the inside.
Old 28 Jan 2005, 06:17 pm
I used the clutch hole plate to run the wires thru and then used silicone caulk to seal it. It was a Bit-- to get out without droping it in the engine compartment, I used a magnet to remove it and then reinstall it.
Old 28 Jan 2005, 08:22 pm
Bumper Bob, if you can't get a big enough hole (you can), spend the money at Radio Shack or wherever to get the terminal removal tool. Map the location of each wire and remove them from the connector. It may take longer, but it will last longer, too! Splicing is the No. 1 cause of failures!
LEDs vs. conventional bulbs pppt03turbo General Turbo Discussions 5 15 Nov 2006 05:33 pm
Undercar LEDs patbluecruiser Exterior Accessories Forum 2 13 Jan 2005 11:56 pm
license plate LEDs Ed Lim Exterior Accessories Forum 6 22 Apr 2004 10:01 pm
Washer LEDs quicksilverdon Exterior Accessories Forum 7 28 Feb 2004 12:23 pm
led's to replace tail lights ptcruzin42 Exterior Accessories Forum 14 23 Jan 2004 01:45 pm
