Go Back   PT Cruiser Forum > 2.4L Turbo Forums > Exterior & Interior Styling
how to hook up a rear floor aux light
Old 11 Dec 2005, 04:58 am
Default how to hook up a rear floor aux light
I decided to install an aftermarket auxiliary light to the rear seat floor area (without drilling holes).
the light was $6 at AutoZone.
attach [+] and {-} wires to the appropriate wires on the aux light, pigtail connect, then seal each connection with heat-shrink tape.
clean the back of the light and the mounting area with rubbing alcohol. Use strong double-sided tape and mount the aux light where desired.
for rear floor locations, the lightÂ’s wire can be run under the rear right seat. Tuck the wires into crevasses where possible.
continue to route the wire along the right side of the cargo area, then connect into the cargo lightÂ’s wiring.
aux light's [+] taps into the pink wire. its [-] wire taps into the greenish-yellow wire. apply electrical tape to the newly tapped wiring.
the aux light now turns on/off as the doors open and close.
[^]-pppturbo03
Old 11 Dec 2005, 10:42 am
Sounds like good directions for anyone wanting to do the same. Anykind of instructions are always welcome.
By the way, your using imagestation which isn't allowed any longer. A lot of us are now using www.photobucket.com (freebie)
Old 11 Dec 2005, 11:04 am
Yea, good info but all we are seeing is a RED X.
Old 15 Dec 2005, 03:09 am
crewzin - i gave up on posting my pics. tried 3 hosting sites, no dice[xx(]. i think it's descriptive enough.
gt model, modified airbox with cold air induction, magnecor plug wires, tyc b/up lenses, chrome grille kit, retro 3d taillights painted steel blue, buick-style portholes, nomad chevy trunk trim, blue interior light strips, and massive turned down diesel-type exhaust tip.
Old 15 Dec 2005, 09:57 am
[quote]quote:Originally posted by pppt03turbo
Actually, the pictures did show up at one time...now there gone. Picture of the floor lamp and the wiring at the rear light. Try that last hosting site again...maybe you couldn't see it, but it showed up here. Imagestation (like BDD said) is the only one that people are having trouble with that I know of.
Rear Hatch Open light stay on? KingKole02 Tech & Performance Forum 5 13 Jul 2004 01:25 pm
Rear door sill scuff pads stronda Interior Accessories Forum 5 04 Sep 2003 05:46 pm
Rear anti-sway bar install on GT JohnM General PT Cruiser Discussions 11 24 Jul 2003 07:38 pm
front and rear light covers turbomangt Exterior Accessories Forum 4 05 Feb 2003 10:04 am
Rattle in rear interior compartment! gtobey General PT Cruiser Discussions 6 30 Oct 2002 10:10 am
