Go Back   PT Cruiser Forum > 2.4L Turbo Forums > Exterior & Interior Styling
best way to remove the radio/center trim?
Old 27 Nov 2006, 08:48 pm
Default best way to remove the radio/center trim?
hi - i need to get at the radio. what's best way to remove the radio/center trim? - without breaking it...
any help would be appreciated. thanks.
Old 28 Nov 2006, 10:08 am
Pry out the window switch - that will expose a screw. Take the screw out, pull off the vent control knobs, and pull the console off.
Old 29 Nov 2006, 10:23 am
I just found this on a UK PT Forum:
http://www.imagestation.com/album/pi...?id=2108479789
Don't thank me....
Old 30 Nov 2006, 06:12 pm
quoteon't thank me....
okay, i wont thank you. i'll just say:
[^]YOU ARE >>>AWESOME!!!<<<[^]
i would have snapped the trim in two, as i did not suspect a screw behind the pw plate. i plan on installing a 12v powered antenna amplifier, so i need to get to the back of the radio.
gt model, modified airbox with cold air induction, magnecor plug wires, tyc b/up lenses, chrome grille kit, retro 3d taillights painted steel blue, buick-style portholes, nomad chevy trunk trim, blue interior light strips, and massive turned down diesel-type exhaust tip.
Old 01 Dec 2006, 05:15 pm
sounds cool keep us poted how it goes [8)]
Old 07 Jan 2007, 05:07 pm
just a heads up before anyone tries adding an in-line 12 volt antenna booster. it can't be done.
the antenna cable going into the radio has a built-in and un-removable plastic locking sleve attached. you can walk out the antenna cable from the back of the radio, but the locking sleve is too big to go into the antenna booster unit. i'm now on the hunt for a longer (more than 31") antenna mast to get better reception.
Old 08 Jan 2007, 08:50 pm
wow that stinks !! [xx(]
Old 09 Jan 2007, 02:39 pm
quote:Originally posted by pppt03turbo
8<snip>8
31" is optimum for FM reception (1/4 wave).
a longer antenna will help with AM, but not FM.
Defend Our Hobby!
Join the SEMA Action Network
http://www.semasan.com
Old 09 Jan 2007, 11:43 pm
good info. i did not know 31" was a target-size for fm reception.
i found a 40" replacement mast antenna at a local auto parts chain. i'm a AM talk radio listener, so the longer mast has worked out great - especially under bridges and when driving along bay area electric trolly train ways.
Old 07 Apr 2007, 09:52 am
<ahref="http://polaris-spa-equipment.hottopnews.info/beauty-therapy-
5 speed question lip General Turbo Discussions 37 23 Apr 2004 02:30 pm
remove silencer ??? SwtNLwPT General Turbo Discussions 4 28 Mar 2004 01:47 pm
beltline trim opinions Curruzr Exterior Accessories Forum 3 18 Jan 2004 12:41 pm
fender trim scribs-turbo Exterior & Interior Styling 0 14 Oct 2003 11:38 am
fender trim brackets scribs-turbo Exterior Accessories Forum 0 13 Oct 2003 03:17 pm
