Go Back   PT Cruiser Forum > 2.4L Turbo Forums > Exterior & Interior Styling
HID Lighting Kit Install
Old 17 Jan 2007, 02:17 am
Default HID Lighting Kit Install
I just finished installing a pair of HID light kits in my 06 GT. My first attempt was without a relay kit and they worked just great with the engine off but would not power up with the engine running. I suppose there is something with the controler that drops the voltage under load if it sees too much amperage to the headlamps. At any rate installing a seperate low beam relay to power the HIDs directly off the battery solved the issue. The problem is now aiming the lamps. I had to bring them up and used a T20 driver to turn the outside screw to raise the beam but now I want to aim the drivers side out slightly since it is aimed too much toward center. The inner adjustment holes do not look like they have an adjustment screw inside them and I can not feel one with the T20 driver. What am I missing?
Old 15 Apr 2007, 02:54 am
Default Re: HID Lighting Kit Install
hey man can u tell me how can i get or make a relay for my hids i have a 06 pt cruiser need to know how to do it please help me out hit me back on my email. juan_nieves@tmail.com please include step by step
Old 15 Jul 2007, 02:29 am
Hi,
I'm from NeverBurnOut, a site sponsor -- do you have DRLs activated? If so, disable them. If not, don't fire up your headlights until you've turned your engine on. Let us know how that goes.
Daniel
NBO
Old 10 Dec 2008, 08:55 am
i amm having a problem installing my HID kit and wanted to know if some one could help. the lights turned on when the car was off but when the car was turned on it would only strobe and then caused a reading of no bus? any ideas on how i can fix this do i need to run a relay? if so how do i do that. oh yeah this is on a 06 pt cruiser
Old 24 Dec 2008, 04:31 pm
I think alot of new cars are having problems HID kits because of daytime running lights and lower voltage given or computer thinking the headlights are out.
LED Lighting blog
Old 08 Oct 2009, 04:32 am
hey friend do you know what is the meaning of HID?It is High Intensity discharge.They produce 3 times more light than any other and they are very powerful in illumination..
How to install lowering springs? Rymanrph Wheels, Tires, Suspension 4 01 Feb 2010 01:30 pm
stage 1 install problem gooberff Stage Turbo Kits 6 29 Jun 2005 12:22 am
Anyone install Borla Dual exhaust? crazie.eddie General PT Cruiser Discussions 16 10 Oct 2004 09:21 pm
BOV Install RODRUN Stage Turbo Kits 7 12 Oct 2003 11:27 am
Lighted Windshield Washers Install onyxgreen Exterior Accessories Forum 3 06 Apr 2003 04:07 pm
