Go Back   PT Cruiser Forum > 2.4L Turbo Forums > Exterior & Interior Styling
Installed dual Gauge pillar pod
  #11 (permalink)
Old 23 Aug 2009, 09:11 am
chris15's Avatar
Default Re: Installed dual Gauge pillar pod
Hey man, thanks for the advice. First, though, about the 194 bulbs.. was that in reference to the gauges in the gauge pod or to my comment about the dash gauges? If its the second, I'm picking up a gauge kit from JCWhitney simply because all of my interior lights are blue, not that teal/seafoam green that comes stock. I like things to match.
I saw those pods over at Race and Street, and am thinking that's where I'll order them from. Just out of curiosity, could you give me a parts list of what you ordered exactly from glowshift? Specifically, I know you mentioned using one of their sandwich adapters for your oil pressure sender, but would like to know which you wound up using. I'm using the 3614 filter, so I shouldn't run into any clearance issues.
Thanks for your help.
2001 PT Turbo - In the process of a major overhaul.. :]
2006 Cobalt SS/SC - Stage 2, 3" Exhaust, Meth and soon to come: Zex 75-shot :]
  #12 (permalink)
Old 23 Aug 2009, 11:19 am
Send a message via AIM to CYCLONE_06 Send a message via Yahoo to CYCLONE_06
I was referring to the gauges in the pod, but if you plan on matching it all, thats different I just picked up some green bulbs to match the stock gauges, and my overhead map lights and console lights are orange, as well as the rear cargo light. My reverse lights and tag light are super whites.
The oil filter sandwhich adapter I ordered was the 3/4 UNF 16. It comes with two plugs, and one open hole. Im not sure how the N/A motor is set up, but where the filter screws in theres an oil cooler on the turbo, with two oil cooler lines. Myself and another guy I already explained this to, ended up turning the sandwhich adapter so that an extension of about 2 or 2.5 inches can be attached, and run between the two oil cooler lines, and then attach your oil sending unit there. Wrap either the cooler lines or the extension in some thick cushion foam, to keep the line and the extension from rubbing / breaking.
You will see what I mean when you crawl under there. I couldnt mount the sending unit straight up, because it would hit the axle, and couldnt mount it straight down because of clearance issues.
~CYCLONE_06
  #13 (permalink)
Old 23 Aug 2009, 03:11 pm
chris15's Avatar
I see. Which gauges did you wind up using? I was thinking about using the tinted 7-color series. I'm assuming since you said you swapped bulbs, you just went with the standard gauges, right?
That's good info. I can't quite remember what's in the vicinity of my oil filter, but I'm sure it's very similar to what you did. I'm definitely going to have to invest in some ramps or something, though.
Another quick question-- when you buy the pod, does it matter what color the pillar is beneath it? (The stock one) Or does the pod not completely cover the stock pillar? Just cause there's someone with a junked PT on here that I'd like to get the pillar from but I'm not sure if the color matters. (Not sure what they have, either.)
Thanks again man, I appreciate it, and I'll probably consult you a bit more as I go through with this.
  #14 (permalink)
Old 23 Aug 2009, 03:25 pm
I went with gauges that have black faces and white numbers, and black frames. I didnt want anything too fancy, and I wanted to be sure I could see the numbers at night. Also, my boost gauge is a boost / vac gauge. So, if you have trouble finding a place to TEE into, just find the line on the throttle body. It reads vaccume also. My gague reads vac all the time. The only time boost moves is if I stomp on it.
You need ramps for sure. Go to wal mart auto section, get the grey or black resin ramps. They are light, and easy to carry, and hold 12000 lbs.
The pillar under the gauge pod, well if it doesnt match you can paint it. My gauge pod completely covered mine, so it worked out well.
Yea, you know how to reach me
~CYCLONE_06
  #15 (permalink)
Old 01 Sep 2009, 09:29 pm
slipstream74's Avatar
Send a message via AIM to slipstream74
Here's my install.
2003 Inferno Red GT Turbo 5sp., Stage 1+ SCT 93 Canned Tune, Mopar wires w/NGK plugs, VAK-5 system with airbox mod., Mopar BOV, Boost/Vac & Oil Pressure gauges, Hurst STS w/ SRT-4 boot & boogers, 52mm auto TB, Magnaflow exhaust, Composite manifold, BWoody CV, 2 catch cans, Mopar body kit.
  #16 (permalink)
Old 02 Sep 2009, 09:13 am
Originally Posted by slipstream74 View Post
Here's my install.
Looks good for sure. Glad I can help you guys out. The vac line on the throttle body is much safer to use than the brake booster line. And that sandwhich adapter really makes life simple. The hardest part was running the tubes / wires, etc.
Slipstream, might I suggest finding some covering for your boost tube... it will help protect it from the heat of the manifold under the hood. I ran mine through a rubber tube I had laying in the garage and it blends in like it came from the factory.
Where does your oil pressure usually carry around 55 to 60 mph ?
~CYCLONE_06
  #17 (permalink)
Old 02 Sep 2009, 09:34 am
Thanks for the advice. I covered my wire to the oil sender with a high temp plastic conduit that seems to be working fine. I'll look into covering the boost tube. After my engine warms up I get 25 at idle and around 50-55 during driving. Its at 75 before warm up.
  #18 (permalink)
Old 02 Sep 2009, 09:57 am
Cool, same numbers im reading. What kinda boost are u reading ? 11 to 12 lbs ?
~CYCLONE_06
  #19 (permalink)
Old 08 Oct 2009, 04:39 am
well what you have done is really appreciating one..your effort is really remarkable....it was not so easy doing because one of my friend has done this and has found it pretty difficult so good job friend....its looking awesome...
  #20 (permalink)
Old 08 Oct 2009, 08:49 am
Thanks ronald.
Cyclone, I'm pushing 17psi max, 15psi redline now with the Stage 1 plus SCT 93 Oct canned tune. Zooma zoom zoom.
part numbers Punch General Turbo Discussions 8 19 Sep 2009 08:44 pm
Full Replacement Gauge Pillar Pod wantaptcruiser Interior Accessories Forum 1 21 May 2009 07:31 am
gauge pillar pod installation intim3 Interior Accessories Forum 4 16 Jun 2008 11:48 pm
Pillar Pod and Gauges installed Mean Green Turbo Performance 25 12 Nov 2004 01:38 am
FS: Dual Gauge Pod jramosGT Classifieds: For Sale/Trade 3 22 Apr 2003 06:57 pm
