Go Back   PT Cruiser Forum > 2.4L Turbo Forums > Exterior & Interior Styling
Any one put factory Fogs on car that did not have them???
Old 29 Aug 2009, 11:13 pm
Question Any one put factory Fogs on car that did not have them???
I looked under my girlfriends car today the wireing is there for the fog lights already so from what I have found on doing this I should only need the fog light housings and the new head light switch the pulls out to turn them on
Ok my ?'s are will the neons switch work on the pt cruisers her's is a 2003 what year neons will work?
Does any one know the part #'s for the headlight switch and the housing since I dont need the whole kit with wireing.
Any info would be great thanks
Old 30 Aug 2009, 12:27 am
Cathy06PT's Avatar
Send a message via AIM to Cathy06PT
Default Re: Any one put factory Fogs on car that did not have them???
Hi there, actually I did that. My PT Did not come with fog lights but if you look under the front bumper, as you said, all the wires are still there. Honestly, I bought the entire kit, OEM parts, off of e-bay for under 100 bucks but I had it installed at the dealer which cost me like 300 just to have them install. It's cheaper to come in with the OEM Parts yourself the to order through the dealer.
Dont install any after-market switch because the kit has it all already. I looked on ebay for you but I didn't see any so you might end up ordering from the dealer. I couldn't find any exact part numbers for you, sorry.
Old 30 Aug 2009, 12:44 pm
I installed them on my 2002, I bought my kit from a dealer, it included all wiring. I was glad as some of the wiring was missing from the car.
Old 30 Aug 2009, 05:36 pm
I have the pdf install from the mopar site and it says if wireing is already there then you only need the multifunction switch and the light housings
is the dodge neon multifunction switch the same as the pt cruisers?
Old 14 Sep 2009, 10:19 pm
Question Re: Any one put factory Fogs on car that did not have them???
BUMP any 1 know?
Old 15 Sep 2009, 09:00 am
Guess not. As you read the above postings, you'll see that the ones that installed stock headlamps used OEM MF switch.
Old 15 Sep 2009, 09:55 pm
part #5073049AB for switch any one know if it works on other chrysler cars?
Old 17 Sep 2009, 10:36 pm
soonercruiser's Avatar
Cool Re: Any one put factory Fogs on car that did not have them???
Yup!
I bought the OEM kit. I installed the fogs myself...but......Went to the dealer to install the MFSwith; and flash the computer.
Frank, aka SOONERCRUISER,
Old 17 Sep 2009, 10:39 pm
Originally Posted by soonercruiser View Post
Yup!
Why did you need to have computer flashed after installing that ??? is it not just plug an play???
Old 18 Sep 2009, 09:16 pm
I dont see why you cant just tap off wire hooked up to current non fog light switch now and put and after market one in its place if all it does is off and on ? any 1 try this?
Factory Brake Pad Variations delucani Tech & Performance Forum 3 11 Mar 2009 07:28 am
factory subwoofer cutting out! need help! BostonBoy Sound and Security Forum 7 30 May 2007 10:50 pm
Factory Hold on GT Convertible Build???? MACE PT Cruiser Convertible Forum 0 20 Apr 2004 12:56 am
Can GT factory tires fit on 17"x7" rims? coolvirus Turbo Wheels/Suspension/Handling 8 06 Jan 2004 07:49 am
Put in factory air box and....... Mean Green Turbo Performance 3 21 Dec 2003 03:16 pm
