Go Back   PT Cruiser Forum > 2.4L Turbo Forums > Exterior & Interior Styling
Wind noise coming from driver side door
Like Tree2Likes
Old 18 Mar 2010, 04:51 pm
Default Wind noise coming from driver side door
Hi there guys,
So like I had mentioned in another post here I recently bought a Black 2005 Pt Cruiser GT High Output Convertible...
I have only ONE problem with it that is driving me a little nuts... It does not happen all the time just every now and then...
On the driver side, in the door sounds like -just below the window- in the door frame when driving at a moderate speed (60km/h) is a windy sound. It sounds like something is not sealed correctly and is letting wind either in which is causing the sound or the wind is hitting something which is causing that sound.
Just curious if this is a problem anyone else has had or heard of?
Thanks.
Old 19 Mar 2010, 09:48 pm
Default Re: Wind noise coming from driver side door
I have the same problem.
WV05Cruiser
2005 Touring Edition - Cool Vanilla
aFe Intake, Scremin Demon Coil, Mopar Performance Plug Wires, Champion Platinum Spark Plugs, Chrome Smoothies, Chrome Door Cups, Chrome Shorty Antenna, Mopar Chrome Exhaust Tip, Chrome Muffler Plate, Chrome Backup Trim Rings.
Old 20 Mar 2010, 08:48 pm
Same problem here as well; except with both window. There is a technical bullitin regarding this problem; just haven't gotten around to it yet.
Old 20 Mar 2010, 09:46 pm
TSB 23-021-05
Body - Wind Noise/Whistle From Side Window Area
TSB NUMBER: 23-021-05
GROUP: Body
DATE: March 24, 2005
SUBJECT:
Wind Noise At Side Window
OVERVIEW:
This bulletin involves relocating the foam stuffer at the end of the door outer belt seal.
MODELS:
2005 (PT) Chrysler PT Cruiser
SYMPTOM/CONDITION:
A high pitch whistle sound from the mirror / door belt area may be heard at 30 mph - 50 mph (either left or right hand side).
DIAGNOSIS:
If the vehicle operator describes the symptom, perform the Repair Procedure.
REPAIR PROCEDURE:
1. Lower the door glass, and remove the interior door mirror trim bezel (trim stick) for access to the mirror attach nuts.
2. Remove the (3) mirror attach nuts (8 mm wrench). Take care not to drop the nuts inside the door trim cavity.
NOTE :The repair can be made without complete removal of the mirror which requires removal of the door trim for access to the wire connector.
3. You now have access to the outer belt foam "stuffer" located at the forward end of the belt seal, (Fig. 1).
4. Relocate the foam stuffer to stick out past the end of the belt seal by 2 mm - 4 mm (1/8 - 3/16 in.).
5. Install the door rearview mirror and attach with 3 nuts.
6. Install the door trim bezel.
7. Test drive the vehicle to verify the whistle sound is corrected.
POLICY:
Reimbursable within the provisions of the warranty.
jimmiebug likes this.
Old 23 Mar 2010, 09:56 pm
Originally Posted by CREWZIN View Post
TSB 23-021-05
GROUP: Body
SUBJECT:
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
DIAGNOSIS:
REPAIR PROCEDURE:
POLICY:
Thanks for the TSB info.
Would you happen the have Figure 1 so I know what I am looking for?
Thanks!
WV05Cruiser
Old 24 Mar 2010, 06:20 am
Sorry, no. The article I got that from didn't have any pictures with it.
Old 04 May 2016, 05:47 pm
Whoa! SWEET!!
I have plenty of sound deadening material. I'll stuff all that in there. I have some annoying noise coming from the passenger side. May as well do both sides.
Thanks mate! I'll try to take pictures for you guys on my 2006 base pt cruiser.
--2006 pt cruiser non turbo owner. Completely stock... For now.
Old 02 Apr 2018, 09:29 pm
Happy's Avatar
I know this topic is old but, if you can remove the weather striping back with out damaging it take piece of 1/4 inch rope tape(every 6 inches) on the inside of the rail putting your rubber strip back in place.Just follow the rail with the rope to the top corner and cut it there. I have restored several old cars and found the the old car builders did this to seal the rubber better because the fit wasn't all that great. I just did this on my 87 Allante to quiet the thing down.
03'PT Cruiser GT and an 05'PT cruiser
Old 10 May 2018, 05:07 pm
Sort of a dumb question, but can you use regular home door insulation for doors on a car?
I definitely wouldn't mind making my ride quieter, specially while driving down the highway
Old 10 May 2018, 05:48 pm
LionPT's Avatar
Do you mean those foam sticky strips..??
You probably could, but you'd have to glue them down & replace every 2-3 years...JMO.
Side-Rear Fixed Window (the small ones) Wind Noise TheAnt General PT Cruiser Discussions 9 26 Jan 2017 02:58 pm
Driver side door lock problem KTBoom2006 General PT Cruiser Discussions 5 13 Oct 2006 08:19 am
Wind noise ctmac General PT Cruiser Discussions 19 16 Dec 2003 03:58 am
Wind Noise crzn8r General PT Cruiser Discussions 19 22 Nov 2003 04:17 am
question on wind noise from side windows comPuTer General PT Cruiser Discussions 14 03 Sep 2003 09:12 am
