23 Aug 2015, 08:26 am
Re: Side window outer pillers removal
Originally Posted by Gareth
Does anyone know how to take the black side pillers off .The front & back ones. Cheers in advance
They are easy to remove, follow these steps:
Originally Posted by rckstein
To remove, you lower the glass and pull the glass weatherstripping out of the channel. In the weatherstripping channel there are some small torx head screws, remove those. Then on the inside of the doors, remove the torx screws at the end of the trim piece that is on the outside of the doors, at the bottom of the glass. On the rear doors there is a screw at each end and you can completely remove this trim piece from the door. On the front doors there is only one screw, at the back of the doors, not necessary to remove this trim from the doors, just remove the screw and loosen the trim piece. Then to remove the pillar trim pieces, from the lip that goes in the weatherstripping channel, gently lift up the trim piece and roll it towards the outer part that is rolled around the door edge. On the back of the trim pieces, at the top, there is a small plastic wedge that may be loose, don't lose those. Reinstall in reverse order. Also, when removing the trim screws, it helps to stuff a rag in the small crack at the bottom of the glass as you may drop some screws down inside the door, if that happens, then you have to remove the door panel to retrieve.
Originally Posted by bubba_1952
'06 Touring Edition NA Automatic
155k Miles / Electric Blue Pearl
USMC '82 - '93
