I have booger bushings and the Hurst STS for the Turbo. Shift throws are shorter and cleaner than with the OEM shifter. how much? Some, but it is noticeable esp on the 1-2 and 2-3 shifts. The bushings give it a more solid feel. I did the shifter and tranny side bushin replacement. Very satisfied...don't even remember what the OEM shifter was like.
Rob
![]() 2003 GT Inferno Red,5-spd,Eibach Springs,Koni Sport Adjustables, Eibach front and rear Sway Bars, Mopar Stage 1,Mopar BOV,Custom 2.5\" Dual Tip Exhaust (Magnaflow),Hurst Short Throw Shifter, Pioneer DEH6500 Headunit, RF Punch 300 and 301 Amps,RF 12\" Sub and MB Quart Reference and Premium Speakers,Ronal RT 17x7.5\'s with Michelin Pilot Sport 225/45ZR17s, Koni Adjustible shocks, Keystone single scoop, GT Airraid Intake, Mopar Ground Effects Homepage: http://www.cardomain.com/id/ptgtredman http://blueman.ptenthusiasts.net/index.html |
the 2-3 shift is basically a straight up motion because the lever is spring loaded to return to center automatically, on the times that i have missed third i'm either in 5th or hit the detent between 3 and 5.
i really didnt think that the hurst was all that much better than the stock one and it didnt seem to shorten the throw as much as advertised, then again i forgot to measure before. the main reason i like the hurst is that i can change the knobs and levers to fit my needs.
www.cardomain.com/id/rallydrock |
Speaking of shifting, even with over 20,000 on my GT, it still does not shift real smooth. I was expecting it to smooth out with time but I guess this thing will never be snot-slick.
The throws are not as short on the STS as I would have liked. I do like the fact the shifter sits higher, probably why the throws are not as short and that the shift ball is larger and fits my hand better. Best of all, it looks a heck of a lot better than the wimpy stock piece!
Gary your going to have to lower you seat to shift. |
Cutting the shaft won't cause the throw to be shorter, only cause's the shaft to be shorter. The connection points between the shifter and linkage do not change. My .02 only, yours may vary...
See Kevin's 2003 Elec Blue GT here: http://www.cardomain.com/ride/477590/1 |
quote "Cutting the shaft won't cause the throw to be shorter, only cause's the shaft to be shorter." unquote
That's exactly what causes the throws to be shorter. Shorten the operating lever, shorten the throw. quote "I do like the fact the shifter sits higher, probably why the throws are not as short" unquote most short throw shifter kits move the pivot point higher, causing the leverage to be less. If the shifter is the same length, the throw will be less. Most stock levers are about 5-1. The knob end moves 5 inches to the linkage end moving 1 inch. Changing the upper length shortens the upper lever which changes the ratio. Changing the ratio (moving the pivot up) to 5-2 (example only) will shorten the throw, with the same length.
2004 Dark Plum Base with windows tinted, cabin filter, silencers removed, fog lights, 18\'s, all Red taillights, Blaine\'s struts, modesty cover, color-matched center dash, 06 rear bumper |
another way to shorten the throw is to relocate the cable at the tranny closer to the pivot point.
| Help! Best replacement half shaft | Kirby | General Turbo Discussions | 0 | 09 Apr 2005 05:57 pm |
| Drive Shaft Question on GT Cruiser | Kboom | Turbo Wheels/Suspension/Handling | 11 | 27 Oct 2004 05:44 am |
| The car feel like crap... a shaft may be Dying?? | Ian-PT-GT | Turbo Wheels/Suspension/Handling | 11 | 28 Mar 2004 12:29 pm |
| Snapped Drive shaft | Exhaust Depot | General Turbo Discussions | 6 | 21 Jul 2003 12:42 pm |
| Manual Shifter Shaft | fourty4mag | Interior Accessories Forum | 1 | 14 Jan 2003 01:31 pm |
