PT Cruiser Forum Car Videos
Car Rims
Go Back   PT Cruiser Forum > 2.4L Turbo Forums > Exterior & Interior Styling
Cutting my shaft
  #11 (permalink)
Old 22 Dec 2004, 12:05 pm
PTGT Redman PTGT Redman is offline
I have booger bushings and the Hurst STS for the Turbo. Shift throws are shorter and cleaner than with the OEM shifter. how much? Some, but it is noticeable esp on the 1-2 and 2-3 shifts. The bushings give it a more solid feel. I did the shifter and tranny side bushin replacement. Very satisfied...don't even remember what the OEM shifter was like.
Rob
Homepage:
  #12 (permalink)
Old 22 Dec 2004, 12:52 pm
the 2-3 shift is basically a straight up motion because the lever is spring loaded to return to center automatically, on the times that i have missed third i'm either in 5th or hit the detent between 3 and 5.
i really didnt think that the hurst was all that much better than the stock one and it didnt seem to shorten the throw as much as advertised, then again i forgot to measure before. the main reason i like the hurst is that i can change the knobs and levers to fit my needs.
  #13 (permalink)
Old 22 Dec 2004, 04:07 pm
Cal Cruzer Cal Cruzer is offline
Speaking of shifting, even with over 20,000 on my GT, it still does not shift real smooth. I was expecting it to smooth out with time but I guess this thing will never be snot-slick.
  #14 (permalink)
Old 22 Dec 2004, 05:47 pm
1ptturbo 1ptturbo is offline
The throws are not as short on the STS as I would have liked. I do like the fact the shifter sits higher, probably why the throws are not as short and that the shift ball is larger and fits my hand better. Best of all, it looks a heck of a lot better than the wimpy stock piece!
Gary your going to have to lower you seat to shift.
  #15 (permalink)
Old 22 Dec 2004, 08:17 pm
OurPTGT OurPTGT is offline
Cutting the shaft won't cause the throw to be shorter, only cause's the shaft to be shorter. The connection points between the shifter and linkage do not change. My .02 only, yours may vary...
  #16 (permalink)
Old 22 Dec 2004, 08:43 pm
purple04 purple04 is offline
quote "Cutting the shaft won't cause the throw to be shorter, only cause's the shaft to be shorter." unquote
That's exactly what causes the throws to be shorter. Shorten the operating lever, shorten the throw.
quote "I do like the fact the shifter sits higher, probably why the throws are not as short" unquote
most short throw shifter kits move the pivot point higher, causing the leverage to be less. If the shifter is the same length, the throw will be less.
Most stock levers are about 5-1. The knob end moves 5 inches to the linkage end moving 1 inch. Changing the upper length shortens the upper lever which changes the ratio. Changing the ratio (moving the pivot up) to 5-2 (example only) will shorten the throw, with the same length.
  #17 (permalink)
Old 23 Dec 2004, 12:28 am
another way to shorten the throw is to relocate the cable at the tranny closer to the pivot point.
vB code is On
Help! Best replacement half shaft Kirby General Turbo Discussions 0 09 Apr 2005 05:57 pm
Drive Shaft Question on GT Cruiser Kboom Turbo Wheels/Suspension/Handling 11 27 Oct 2004 05:44 am
The car feel like crap... a shaft may be Dying?? Ian-PT-GT Turbo Wheels/Suspension/Handling 11 28 Mar 2004 12:29 pm
Snapped Drive shaft Exhaust Depot General Turbo Discussions 6 21 Jul 2003 12:42 pm
Manual Shifter Shaft fourty4mag Interior Accessories Forum 1 14 Jan 2003 01:31 pm
  Credit Card | Mobile Phone | Personal Finance | Personal Loan | Mortgage Calculator
