Go Back   PT Cruiser Forum > PTCruiserLinks.com > Feedback and Support
2001 PT Cruiser check engine light reset
Old 18 Aug 2012, 05:20 pm
Cool 2001 PT Cruiser check engine light reset
I recently put oil into my PT Cruiser and after... the check engine light came on. I then disconnected the negative post on my battery for 5 minutes...while disconnected I turned the key on twice..to zero out the panel. Waited the 5 minutes and reconnected the battery and the car started and so far the check engine light stayed off. I hope this solved my problem of the check engine light.
Old 18 Aug 2012, 08:12 pm
Default Re: 2001 PT Cruiser check engine light reset
Your the only one that can tell if you cleared the code. It should have.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 19 Aug 2012, 10:16 am
HI .. Can the same thing be done for the passenger airbag light? It comes on when someone is in the seat and dings.
Old 19 Aug 2012, 11:58 am
NO. It only works with the engine light. But worth a try. Just disconnect the negative battery terminal for a few minutes.
Old 19 Aug 2012, 12:06 pm
It's probably the wiring with the passenger seat. I'm not sure if the seat belt is involved or not.
Reset Check Engine Light JoycesPT Turbo Performance 5 05 Jun 2011 12:37 am
2001 Check Engine Light is On ceil99 Tech & Performance Forum 1 21 Mar 2011 09:38 pm
'06 Cruiser Check Engine Light. plumbertom Tech & Performance Forum 6 04 Jan 2011 11:41 pm
Alternative way to reset the check engine light? drbranko Tech & Performance Forum 3 11 Apr 2009 12:43 pm
