Go Back   PT Cruiser Forum > PTCruiserLinks.com > Feedback and Support
How to check your doors lock solenoid
  • 1 Post By LionPT
Old 23 Jan 2015, 10:23 pm
Default How to check your doors lock solenoid
Hi
I have a 2003 base PT Cruiser. When it rains the locks go up and down. After a day they usually stop, the last rain in Southern California the locks would not stop going up and down until the battery was dead. I read on a post that the solenoid can get moisture in them, causing this problem. I need to know how to check the solenoid to find which ones are bad in the doors.
Thank you,
Leroy
Old 23 Jan 2015, 11:10 pm
LionPT's Avatar
Default Re: How to check your doors lock solenoid
I don't think the problem is the solenoid, there 4 in your car & are independent of each other...it could be the RKEM (Remote Keyless Entry Module).
I would pull all 4 door panels & check the plug, mounting bolts & solenoid arm.
If you want to test them...pull one out at a time, use small test clips and attach 2 clips the the solenoid & 1 to the + side of battery & touch the other to the - side. The solenoid should move either in or out...reverse the + & - leads to test the other way.
Old 26 Jan 2015, 04:34 pm
Thank you.
2002 LE ptc doors does not central lock, interior lights and temperature reader and a stanley Tech & Performance Forum 2 04 Feb 2013 12:24 am
RIGHT FRONT DOOR DOES NOT LOCK THE OTHER DOORS luisen General PT Cruiser Discussions 5 03 Apr 2010 03:33 pm
To lock the doors and liftgate Paulo General PT Cruiser Discussions 0 26 Dec 2009 02:47 pm
Doors lock & unlock for no reason molnar441 General PT Cruiser Discussions 3 01 Oct 2008 02:12 pm
Doors lock & unlock for no reason molnar441 Tech & Performance Forum 2 20 Aug 2008 03:18 pm
