Go Back   PT Cruiser Forum > PTCruiserLinks.com > Feedback and Support
Power windows, A/C not working air bag light on... Etc..
Old 15 Jul 2016, 10:02 pm
Default Power windows, A/C not working air bag light on... Etc..
I currently have a 2002 Pt Cruiser none turbo limited edition. My A/C won't turn on and the power windows won't roll down and the air bag turns on but plus side my sun roof works. Also, the fuse for my radiator fan keeps blowing. I have replaced the pink and black wire that runs from the fuse box to the power windows and A/C console, but I am at my wits end with this car. Please help me!!
Old 15 Jul 2016, 10:09 pm
Default Re: Power windows, A/C not working air bag light on... Etc..
I would suggest you check the wiring harness under the engine. There is a plastic clip that is common for breaking on the 2001 & 2002 PT Cruisers that holds up the wire harness from hitting the halfshaft and frame. Also check the radiator plug. Sometimes if the radiator starts to draw excessive current it can start melting the plug and start shorting it out.
Has the radiator fan been replaced? If not how long has the radiator fan been in the PT Cruiser?
Did all these problems happen at once?
Post back what you find.
Old 15 Jul 2016, 10:22 pm
These problems did all arise at the same time. I don't know if the radiator fan has been replaced. I have only had the car for a year.
Old 15 Jul 2016, 10:33 pm
Looks like you have a short somewhere. I would start with the wiring.
Is your engine light on? If so what are the engine trouble codes?
Tags
a/c problems, power windows, radiator fan
Front power windows no longer working...? whitbyPT Interior Accessories Forum 59 19 Jul 2016 05:50 pm
Power Windows/Blower/Rear Defrost/Reverse Lights Not Working Jetta02awp General PT Cruiser Discussions 11 07 Oct 2013 01:48 pm
Rear power windows not working Thecoma Interior Accessories Forum 12 27 Sep 2013 12:38 am
power windows not working hillbilly678 General PT Cruiser Discussions 5 30 May 2013 05:36 pm
Third Brake Light and Dome Light not working metalcruiser General PT Cruiser Discussions 5 27 Feb 2012 04:03 pm
