Water in Foglights
Old 16 Jul 2005, 03:12 am
Default Water in Foglights
I have a '03 GT and had to drive through some high water to get out of a rainstorm. While the car is unharmed electrically, I collected some water in the foglights.
Would I be able to drain it by pulling the lights and removing the bulbs?
Old 16 Jul 2005, 03:48 am
I had the same problem but the dealer replaced it under warranty, so yours should be under warranty.
Old 16 Jul 2005, 12:52 pm
I don't know if that would work because I had to replace a low speed fan module and the horn due to water. Wouldn't these red flag my vehicle as far as warranty claims go?
Old 17 Jul 2005, 12:49 am
I picked up water in my fog lights about 1.5 months ago after a rain storm; I had to drive through some unexpected puddles that were deeper than I had imagined. Mine wasn't so bad I had to drain it, and it just evaporated over time. I would think you should be fine to take out the bulbs and remove the housings. They're pretty easy to take out - putting 'em back in is a bit trickier, but it should only take you a short while. You will likely need to remove the splash-guard from the wheel well.
2003 Classic Edition, 5-speed with 7-ball shift knob, badges removed, dark tint, Borla split exit exhaust, short billett antenna, Nu-Image white-faced blue flamed gauges and 15\" American Racing Aero Wheels.
Old 17 Jul 2005, 01:05 am
My hats off to Cruizin2K but most dealerships don't even want to hear about problems like this with the fog lamps. They just say that a rock or something caused the problem and now its your problem not theirs. My business partner has a bmw and had a fog lamp problem and they basically told her to F off, mean while $250 later.
Old 18 Jul 2005, 07:55 am
Rather than take out the housing, use a shop vac and duct tape a piece of old garden hose to the end, then stick the garden hose into hole where bulb came out. (I used that trick to suck scale out of my hot water heater - went thru electrical heating element hole).
My water injection pics EngineRunup General Turbo Discussions 10 04 Mar 2006 03:08 am
PT Under Water CREWZIN General PT Cruiser Discussions 3 16 Jul 2005 02:50 am
Check & drain you water heaters, A/C , &.... Espresso Non-PT Discussions 17 12 Jul 2005 11:47 am
Water dribble while waxing robinjoe The Detail Shop 5 13 Aug 2004 11:25 pm
water Jimbo Non-PT Discussions 3 12 Aug 2004 07:30 am
