question on platinum plugs for 2001 N/A
Old 01 Aug 2005, 01:41 pm
Default question on platinum plugs for 2001 N/A
I know this has been mentioned many times in the past, but I just want to be sure. It's tune-up time for my 2001 N/A Ltd. I called the dealership to get a quote. When I asked about using platinum plugs they said it couldn't/shouldn't be done. Is this just ignorance, or is there a potential service issue here? They said the computer might not correctly interpret the presence of the plugs, etc. etc.
Could I cause myself any problems by switching to the platinum plugs?
What to do?
Old 01 Aug 2005, 02:10 pm
The dealer is full of crap...as usual. There's hundreds of us that have been using the double platinum plugs for thousands of miles with out a problem. They just don't carry it at the dealers and want to sell you what they have. The old Champion number is #7440 for the Double Platinum plugs, the new number is #7570. They'll both work fine. Make sure you go for some decent upgraded wires too. The Crane wires from Race & Street are highly recommended.
http://www.raceandstreet.net/Merchan...ategory_Code=P
Oh yea, one more thing....please use the anti-seize lubricant on the plug threads and dielectric grease on the wire ends that go on the plugs...it will save you trouble in the long run.
Old 01 Aug 2005, 02:23 pm
Thanks for the clarification. If I end up taking it to the dealer, may I quote you?
Old 01 Aug 2005, 02:28 pm
I am at 36K miles on a 2001. Do you think I should replace the wires at the same time?
Old 01 Aug 2005, 02:59 pm
dev dev is offline
You should replace the wires at the same time, if they have not
already been done. [8D]
Old 01 Aug 2005, 08:47 pm
I had the same problem with my dealer at my 30K tune up, they even picked up the 7440s I requested but refused to install them, they even claimed to have called mother Chrysler about it. They had the stock plugs in when I came to pick it up so I just blew it off for another 30K. I put in the 7440s & Crane wires myself for my 60K service.
02 Silver Classic 5 speed with lots of chrome.
03 Cranberry GT A/S debadged.
Make a fast friend, adopt a greyhound.
Old 01 Aug 2005, 11:12 pm
Put the double Plats in our 2002 at 28k miles last year before the Myrtle Beach show and have 34k now. No problems, also replaced the wires with MOPAR performance wires at the same time.
Our 2003 has 18K, so I have a little ways to go before I change them.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Old 02 Aug 2005, 08:56 am
Yes. On my '02 I developed a slight miss at teh mid-30K miles - replaced plugs, still had miss - put in Crane wires, miss gone.
The stock wires don't last.
Old 02 Aug 2005, 09:54 pm
Send a message via AIM to wbslws
I installed Champion Platinum Plugs at 30,000 miles and discarded the stock wires and have had no problem. Took the plugs out to inspect them at 60,000 miles and they showed no wear whatsover. I cleaned them and reinstalled. I regapped them for .042 and wow what a difference.
<b>Consciousness: That annoying time between naps.</b>
Old 04 Aug 2005, 01:58 pm
Stone-PT's Avatar
I recently installed Autolite Double Platinum plugs gapped to .040 and Magnacore yellow 8.5mm high performance wires. My Cruiser has never run better.
www.Stone-PT.com
WELCOME TO THE UNITED STATES OF AMERICA.
Press "1" for English.
Press "2" to disconnect until you have learned to speak English.
Platinum Plugs - Must change timing?? bnorth Tech & Performance Forum 8 21 Jul 2007 10:15 pm
Spark plugs: newbie question Edwin Astacio Tech & Performance Forum 12 01 Nov 2004 12:21 pm
platinum plugs airevac19 Tech & Performance Forum 5 21 Apr 2004 11:30 am
another question re platinum plugs pingber Tech & Performance Forum 7 31 Aug 2003 12:55 am
Platinum Plugs Not Tex Tech & Performance Forum 10 28 Jun 2002 07:12 pm
