PT Cruiser Forum Car Videos
Car Rims
Hatch latch malfunction
Old 29 Aug 2005, 02:18 pm
Dragula Dragula is offline
Default Hatch latch malfunction
I talked my mother into getting a Cruiser and she loved it until her hatch started giving her problems. It's been extremely frustrating for her.
It will close, but the interior lights wont go out and the hatch open light stays lit. It just doesn't latch fully. She has the new style hatch closure with a solenoid rather than a mechanical handle.
They are totally replacing the latch under warrantee when the parts come in. Has anyone experienced the same thing? I was just curious to see if this has been a common problem.
Old 29 Aug 2005, 02:22 pm
I have found that the hatch requires a good slam to get the light to go out - both my '02 and '05 behave the same way. If I just shut it, more often than not the light will stay on.[:I]
Old 29 Aug 2005, 02:29 pm
Yeah mine is the same way. Aparently this is much worse. The mechanic at the dealer was able to recreate the problem, or they wouldn't be repairing it. No matter how hard you slam it the light doesn't go out.
Black 03 PT Turbo & Black 94 Impala SS
Old 29 Aug 2005, 02:33 pm
Espresso Espresso is offline
No problems here. Not nessessarly a slam but a good shut is required. You have to remember, you need alot of pressure to overcome those shocks that hold it up. That hatch isnt light by anymeans. I have a hard time myself, because it's really hard for me to lift my arms over shouldr height, especially with any weight on them. So it is rather difficult soemtimes.
Why ar ethey replacing it? Why just not adjust the striker?
Old 29 Aug 2005, 08:42 pm
Hooligan Hooligan is offline
I'm not sure that there is an adjustment. By replacing it, it should be fixed, if not, it has to go back.
Old 29 Aug 2005, 10:30 pm
I've never seen a striker that wasnt adjustable. They have to be because they are all not cast the same. You need to have adjustment for the tolerances.
I'm not taking about the lock on the hatch. I'm talking about the striker mounted to the body. It acts just like a door striker.
Loosen the bolts & you will see that it moves. It wont move much maybe .25"
Old 30 Aug 2005, 11:29 am
They made a couple of attempts to adjust the striker, but it didn't solve anything. She actually took it to two different dealers to try that.
Old 15 May 2006, 09:36 pm
funkyfermin funkyfermin is offline
I had the same problem of the rear hatch light indicator staying on while I was driving. So I took it in and this is what they said "Found Body connected on left rear quarter pillar pin not making contact." Now it works.
vB code is On
Error Codes skylight Tech & Performance Forum 6 07 Apr 2007 02:19 pm
Rear Hatch Opener Install ? StevenAndEva Sound and Security Forum 1 24 Feb 2006 12:23 pm
Tranny She is a no-good! scottscars Stage Turbo Kits 15 16 Oct 2004 11:11 am
Hatch no longer turns inside lights on Dalite General PT Cruiser Discussions 3 28 May 2003 12:17 pm
PT Cruiser Hump Trunk Hatch ptcruiserparts Vendors & Buyers Forum 2 08 Oct 2001 06:06 pm
  Mortgage Calculator | Personal Loans | MPAA | http://www.Openroads.com | Car Finance
