Vibration @50mph
Old 03 Sep 2005, 02:00 am
Default Vibration @50mph
I'm not sure where to post this but, I have '02 Pt which I enjoy very much - - I have a vibration in the front end somewhere. I had the tires rotated last week end left from Katrina!! At 50 the radar detector is ready to fall off of the window!! It was doing this before the rotation but it's still there and I remember a post about bad axle shafts!! My pt has 38,000 miles on her and she seams really solid!! I also have Bridgestone Potenza tires with 14,000 miles on them. Tread still looks great!! Any help would be great!!! there is no shimmy in the wheel. just the bouncing. I also took it out of gear a few times - - it still does it!!
Old 03 Sep 2005, 02:11 am
Check the balancing of the tires. If a weight fell off, it would cause a vibration in the wheel, usually noticeable at certain speeds. If not, then check the bushings and control arms. Next, with the car up (wheels just hanging) and car off, push and pull the tire sideways to check the tierods then push and pull the top and bottom to check the ball joints. Do this for each tire. If everything comes out right, then it most likely is one of your axles is bent, even if it's unnoticeable.
Old 03 Sep 2005, 12:09 pm
To check the ball joints, you have the weight on the PT on the ground and if you can move or wiggle the "stump" of the grease fitting on the bottom of the ball joint, it needs to be replaced.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Old 04 Sep 2005, 10:03 pm
I'm sure that you have checked. But just in case check the tire pressure
my wife complained of the same problem one day. I checked the pressure snd they had about half of the recomended pressure. Since the load rating of our tires is so high the side walls wont look low but they will be. Good Luck and keep us informed.
But the fact that some geniuses were laughed at does not imply that all who are laughed at are geniuses. They laughed at Columbus, they laughed at Fulton, they laughed at the Wright brothers. But they also laughed at Bozo the Clown.
Carl Sagan (1934 - 1996)
Old 06 Sep 2005, 01:45 pm
I agree with SuGamer's advice. Start with the balancing. I would suggest getting the wheels "statically balanced" rather than using the standard rim-mounted wheel weights. The static weights use adhesive and are mounted inside the wheels, which keeps your wheels looking nicer (no weights are visible). I've had mine using these for more than a year and I really like it. The price for balancing should be the same.
Old 07 Sep 2005, 10:04 am
Balancing is most likely culprit. If you still had the Good-for-a-Year tires, I'd suspect them as well. Go for a balance and see, then follow the other steps.
Unless you regularly drive along railroad tracks or do braille driving, at 38,000 miles you shouldn't have major problems.
harmonic vibration rszappa1 Wheels, Tires, Suspension 17 15 Feb 2006 11:39 am
vibration causing dash to rattle Easymover Tech & Performance Forum 3 26 Jan 2006 07:34 pm
40 to 60 mph Vibration Update fixed gtbright General Turbo Discussions 5 05 Sep 2005 06:51 pm
Steering Vibration qimoves Turbo Wheels/Suspension/Handling 6 12 Jun 2005 05:45 am
40-45 MPH Vibration in a new '02 PT Automatic Mopar Madness Tech & Performance Forum 14 31 Jan 2003 11:44 pm
