Relay
Old 06 Sep 2005, 05:57 pm
bruent's Avatar
Default Relay
Does anyone know where the relay is that controls the power mirrors. They are not working and have checked all fuses, they are fine, so I was told it must be the relay. Any help would be greatly appreciated. I will put this on other forums to see if I can't get an answer. But if you know please respond..
Thanks
Bruce[:I]
Old 06 Sep 2005, 06:51 pm
Bruce,
My manual doesn't say anything about any kind of relay if the mirros aren't working. They say to check the fuse and if that's OK, then remove the mirror control switch and have the continuity checked. Listen carefully for the sound of the electric motors running in the mirrors. If the motors can be heard but the mirror glass doesn't move, there's a problem with the drive mechanism inside the mirror.
Old 27 Sep 2008, 06:52 pm
Default Re: Relay
I accidently connected positive the positive battery cable to the negative post when swapping out the battery. I blew a few fuses which i've replaced, however, my A/C blows warm air.
I was told to replace the A/C fuse but i'm unable to find it. I was also told to check the A/C relay and i'm unable to find that either. Can someone please tell me where it is?
2006 Touring Edition
I appreciate the help.
A/C Fan Relay? KingKole02 Tech & Performance Forum 7 22 Mar 2006 04:20 pm
POWER WINDOW MOD WAYNEF Interior Accessories Forum 13 13 Jan 2005 05:40 pm
Good/Bad news horns turbomangt General PT Cruiser Discussions 25 20 Feb 2004 06:36 pm
