I have a 2001 PT. Recently in the past month when turning to to left, to slow down to stop for a crosswalk for example, the engine dies. Tried re-starting, car tries to turn over, doesn't start.
Take the key out, re-insert into ignition, then car will start. Thought it was an ignition type issue, this was replaced, issue has not gone away. Any ideas??? |
intermittent problems are the toughest. I'd say tighten all grounds (good idea anyway), check the PCM and steering column connector terminals.
Using a scan tool, the length of time until a code sets can be shortened. This is one way to diagnose spastic wiring.
2004 Dark Plum Base with windows tinted, cabin filter, silencers removed, fog lights, 18\'s, all Red taillights, Blaine\'s struts, modesty cover, color-matched center dash, 06 rear bumper |
The first time it happened, the car was towed to a shop to be diagnosed. They put it on the computer and nothing showed up. The check engine light doesn't come on. It is going into the shop next week to see if they can drive it and have the issue happen. I'll mention your idea. Thanks.
PT is an Automatic. Replaced was ignition switch and cylinder.
no wires or plugs have been replaced.
At least at or about 20,000 miles change plugs Champion 7440/7570 gap at .040, Chrysler Preformace Wires P 4876511 ($48) or Magnacore from Race & Street.
Use dielectric grease on plug wires and anti-sieze on the plug threads. They are not hard to replace, remove Intake and use a bungee cord to hold it out of the way, and remove/replace one at a time. Theey are torqued as well as the 5 bolts used on the intake. Not sure of the torque specs for either. Maybe someone else can give that info. |
| Blew a stop light | thegoldpt | Non-PT Discussions | 14 | 31 Mar 2006 08:04 pm |
| Jolted to stop | Jetcab | Tech & Performance Forum | 4 | 03 Nov 2004 12:55 pm |
| I can't stop, somebody help me!! | Mike-in-Orange | Exterior & Interior Styling | 8 | 08 Mar 2004 04:38 am |
| stop tech brakes | PT Chix | General PT Cruiser Discussions | 0 | 22 Jan 2004 09:58 pm |
| Hose to block to stop fuel cut? | PETEY_CRUISER | Turbo Performance | 3 | 21 Jul 2003 06:12 pm |
