I've been towing a 2002 PT Cruiser with manual transmission. The
ignition switch has 5 positions: Lock - Off - Acc - On - Start. All I've had to do is put the transmission in neutral, and the ignition swith in Off, which means the steering column is unlocked, but otherwise the battery is not being drained and the odometer is off. I just took delivery of a 2006 manual PT Cruiser. The ignition switch only has 4 positions....Off is missing. It doesn't seem wise to pull the car with the potential of locking up the steering (it's not locked as long as the steering wheel is straight up), and putting the ignition switch in Acc will drain the battery and rack up mileage. I suppose there's a fuse or two that can be pulled. I'm thinking the easy way out is to remove the pin that locks the steering wheel....I could live without that. I was also told that the Off position has been missing since the 2003 model. Has anyone solved this problem already? |
You may need to go with a tow dolly something like this....
http://secure.rvtoystore.com/catalog...ies/index.html |
Doesn't the owners manual have a section that talks about towing? The early model do. [:I]
I don't really have time to do a search but there is someone or two that tow their cruisers behing their motor homes.
Do NOT try to tow your PT with the key in the lock position. Use the ACC position. As you tow, the wheels on your PT will turn to the right and left significantly as you corner causing the steering wheel lock to activate.
You will find that the battery drain may be somewhat greater than with your 2002 but is generally not a problem unless you tow for more than 8 hours a day or have a supplemental braking system that plugs into the power port. I have a Brake Buddy which uses additional power so I purchased a solar panel which I Velcro to the dash to keep in place and use a cigarette lighter adapter that allows both the Brake Buddy and the solar panel to be plugged into the always on power port on the dash. The key controlled power ports do not work with the key in the ACC position unfortunately (at least they don't on my 2003). The car will not accumulate mileage in the ACC position.
2003 Almond GT AutoStick, body colored rear splash guards and hood struts, chrome gear shift, AC & vent knobs, billet steering wheel spokes and pedals, AMX1397 Turbo-Intake Pipe. |
| 2006 PT Street Cruiser Route 66 Edition | skylight | PT Cruiser News and Rumors | 35 | 17 Nov 2007 02:39 pm |
| 2006 GT Hardtop with 8" SubWoofer | SteelBlueGT | Sound and Security Forum | 0 | 11 Nov 2006 02:01 am |
| Employee Pricing on remaining 2006 PT Cruisers | skylight | PT Cruiser News and Rumors | 0 | 09 Jul 2006 12:29 pm |
| 2006 PT Cruiser Pics and New Specs | skylight | PT Cruiser News and Rumors | 14 | 13 Nov 2005 08:46 pm |
| Chrysler's 2006 Plans revealed.. | pt_tom | PT Cruiser News and Rumors | 7 | 31 Aug 2004 02:33 pm |
