I just took my 2006 pt cruiser for an alignment after installing eibach springs.I was told that the toe is off on the rear drivers side tire.Does anyone know of a kit that i can buy to correct this?
If the person doing the check doesn't know, take it somewhere else.
These are flange shims available and used on many FWD vehicles.
2004 Dark Plum Base with windows tinted, cabin filter, silencers removed, fog lights, 18\'s, all Red taillights, Blaine\'s struts, modesty cover, color-matched center dash, 06 rear bumper |
http://www.autotrucktoys.com/ptcruis...P3779C599.aspx ![]() |
John & Terry ![]() "His" - 2002 Inferno Red Touring Edition "Hers" - 2003 Electric Blue Limited Edition Del Val PT Cruisers |
Yeah ........my problem is with the rear.The front i did need the alignment kit.I was just wondering if anyone knew what to do with the rear.I found a kit from gold line that list shims for the rear so maybe that will work.
http://www.cardomain.com/ride/2203682
Yup. Rear uses shims - I hit a pohole with my '02 and it needed shims for rear.
\'05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler, E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5\", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in \'02 Silver Touring Edition w/87,000 miles |
Years ago I had a Plymouth Reliant and when I had an alignment done, they told me it needed a certain thickness shim placed under the upper right bolt holding the bearing to the axel on the right side of the car. They said it was not out by much and they knew I could do the work ( unbolt bearing housing and install shim and re-assemble). Their cost was high because it was a bit time consuming.The cost of the shim was under a dollar.
Thanks for all replies.If anyone else has this problem these are the part #'s from goldline that can correct it.
PT Cruiser front part # 81260 (-1.75 to +1.75) EZ Cam (2 Req'd) Rear part #75200 (-1.5 to +1.5) EZ Shim
thanks for the info !![?]
| Rear Hatch Opener Install ? | StevenAndEva | Sound and Security Forum | 1 | 24 Feb 2006 12:23 pm |
| Replace/install both sway bars or just rear? | im4gzs | Turbo Wheels/Suspension/Handling | 11 | 23 Feb 2004 09:11 am |
| ..rear axle adjustment? | earringboy | Turbo Wheels/Suspension/Handling | 2 | 03 Jan 2004 07:59 pm |
| Rear door sill scuff pads | stronda | Interior Accessories Forum | 5 | 04 Sep 2003 05:46 pm |
| Rear anti-sway bar install on GT | JohnM | General PT Cruiser Discussions | 11 | 24 Jul 2003 07:38 pm |
