Check Problem Codes Yourself!
Old 21 Dec 2005, 10:38 am
Default Check Problem Codes Yourself!
I wasn't sure where to post this so I thought this gets the most traffic, a fellow Cruiser member (AJ) dropped by my house yesterday and showed me a trick I never knew about. You can check yourself if any problem codes ring up on your Cruiser. all you do is put the keys in the ignition, turn to on and off (don't start engine) 5 times, on the 5th ON position leave it there and look at the odometer. if you car checks out you will see it read "done" in my case it displayed 2 codes. if you show a code you go to allpar web site and look up the codes #'s My two said, I had stage 1, which I did, plus that my battery was moved, which I also did. this was so cool to discover, maybe most of you know this but I'm sure a few didn't. gary[?][^]
Old 21 Dec 2005, 11:24 am
Gary, that info has been around the forums for a while. Only one correction, 3 times is the magic number to turn the key to the "on" position without starting.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Old 21 Dec 2005, 09:38 pm
[8)]Chrysler has always been user friendly. Way back in 1987 on my Lebaron...you could get the codes the same way....also my 1989 Plymouth Acclaim also was the same way....
Old 22 Dec 2005, 09:05 am
Thanks Gary, I already knew that ,but I'm sure some didn't.
It's good to get this information out as there are new people joining every day.
04 cool vanila Limited Turbo
Wife has a 03 limited
(Steel Blue)
Old 22 Dec 2005, 12:24 pm
JGN JGN is offline
Thanks for the info Gary
Not all of us on here knew that information.. Me for one
Thanks again
Old 22 Dec 2005, 08:15 pm
hey gary, it is three times forward ( not starting) its pretty cool that we can check ourselves !!
Old 22 Dec 2005, 09:02 pm
Now that you know how to check the codes, do you know what the codes mean?
Old 23 Dec 2005, 01:57 am
This also works with Fords.
Stick a potato up the tailpipe and watch it turn into a POS before you ever would have know otherwise.
Old 23 Dec 2005, 07:23 pm
JGN JGN is offline
Id like to know that myself,, I didnt see the codes listed in the manual [:I]
Old 23 Dec 2005, 08:16 pm
Click on this link, once you got the code list print it out and keep in the glove box or something.
http://www.ptcruiserlinks.com/forum/...rchTerms=codes
"Check Engine" idiot light on AGAIN tezz General Turbo Discussions 15 23 Jul 2010 06:09 am
Check engine light, ever hear of these codes? MINIHEMI46 Turbo Performance 15 09 Mar 2010 08:58 pm
I think I'm having a power steering problem! lumofny Tech & Performance Forum 5 18 Jan 2005 01:12 pm
Unknown RPM surge problem (manual) Ctown Tech & Performance Forum 4 26 Dec 2004 08:48 pm
Check engine light on - & NO CODES?!?! CraigO Turbo Performance 9 20 Dec 2003 02:42 am
