Emission sensor on, engine hesitation
Old 25 Jan 2006, 05:16 am
Default Emission sensor on, engine hesitation
Im just started having a new problem with my '03 turbo yesterday. My emission light came on (on the lefthand side of the console), and then the car almost jumps backward in 1st through 3rd gear at about 2500 rpm and then returns to normal. I have had problems twice before and I have changed my plugs once and my plug wires once to solve a different type of hesitation problem. It almost feels like im missing a whole cylinder when it hesitates, which would be the worst case senerio. At the same time, once I hit fourth gear tonite, it seemed to not happen. I check the fluids and other major components regularly, and I am going to check the plugs and wires tomorrow. I have had problems with faulty plugs and wires which caused the same warning light to come on because of unburned fuel being dumped into the exhaust but this seems different. It is almost a total stall for a split second. Please any insight would be appreciated.
Old 25 Jan 2006, 09:37 am
Since the MIL is lit, maybe reading the codes would give a path for diagnosis.
Old 25 Jan 2006, 09:48 am
Stop by an autozone, Advance Auto, etc - they'll read your error codes for free.
Why guess? Codes will steer you to problem.
Old 25 Jan 2006, 12:59 pm
I had this same problem with my Supercharged PT. I had to reaplce one of the O2 sensors on the Cat. They can go bad from time to time. Plus the amount of heat generated by the Turbos and Superchargers sometimes burns them out. There are 2 Oxegen sensors, one on the Exhaust Headers, and one on the Catalitic Converter. It is most likely the Cat one that needs to be replaced. But check your engine codes FIRST. I bet it will give you an error saying the O2 sensor is reading the car is runing to lean and needs to be richened up. But as you know, the CPU is suposed to take care of that. That is the first sign that your O2 sensor is going bad. Hope this helps.
By the way, I had an AEM air/fuel ratio gauge installed in my PT so I could monitor this better. It helps to see if you are running to rich or lean. The new ones that are out there are VERY expensive ($345), but it they are more accurate with an anolog L.E.D reading instead of the usual needle reading. They also come with a new O2 sensor which replaces the stock one instead of just splicing into the stock O2.
Old 25 Jan 2006, 06:27 pm
Could be a cam or crank sensor too.
2004 TE Turbo Auto (Silver)
Mopar Stage 1 w/ Mopar BOV, Mopar CAI, 2.5\" Dual Outlet Heartthrob Cat Back Exhaust System, Gold Line lowering springs 1.50\" front and 2.00\" rear and APC Gen II Euro Tail Lights.
Old 25 Jan 2006, 06:42 pm
Dam sensors!
Old 25 Jan 2006, 07:09 pm
wow !! sound s like the same problem i had with my first 03 turbo dealership had car for 47 days could never fix it !! gave me a new car!! keep us posted !!
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
Complete Engine Swap TaylorMade General Turbo Discussions 35 05 Jan 2005 03:34 pm
