Airbag light issues
Old 30 Jan 2006, 07:16 pm
Send a message via AIM to jmack
Default Airbag light issues
Hey guys,
ON my way to work this morning my airbag light came on in the instrument panel, as I was turning into the gas station. I got to work and went in. On lunch it went off for about 10 minutes then it came back on as I made a hard turn into the parking lot.Then on my way home, it immediately went off again and hasn't been back on again...What would this be? Bad sensor? any idea how much it costs to repair this problem? Anythign that I can do?
Old 30 Jan 2006, 09:25 pm
You need to have the airbag codes read with a scanner.
Only then can you begin diagnosis of the faulty circuit to determine if a sensor, wiring, or controller has failed.
Old 31 Jan 2006, 06:40 pm
if you put the key all the way forward and back and do it a total of 3 times ( dont start the car) see if a code pops up where the mileage is
Old 01 Feb 2006, 12:18 am
Bob,
That will only test for emissions system engine codes.
The other 3 hundred codes that PT can generate will not read on the odometer.
Old 01 Feb 2006, 12:41 am
Has the airbag ever been deployed? If not, the dealer should look at it. If so, or if you bought it used, and do not know, then the dealer should look at it.
quote:Originally posted by
jmack
Hey guys,
\'03 PT Turbo 2CN
Auto/Stick
Lt. Almond/cloth
Blanes HoodStruts
etc.
Old 24 Feb 2011, 01:13 pm
Default Re: Airbag light issues
Has anyone figured out how to fix the problem with the airbag light and seatbelt alarm? I have and I just didn't want to post something that has already been addressed. please let me know thank you... JRod
Old 24 Feb 2011, 01:19 pm
yaris's Avatar
check your seats sensors connections, I got a airgab light a while ago after putting some stuff under the front passenger seat, the connections of the sensor was loose I just messed a bit with them the the light got away
Old 24 Feb 2011, 02:44 pm
yaris, read the posting, he found the fix for that problem!!!
Old 09 Oct 2011, 07:29 pm
Hey there,
How exactly did you fix the issue?
I am always sticking things under the seat and I think maybe my airbag light issue may be the same issue.
Where exactly do I find this sensor/wiring? And what should I look for? What does it look like?
Thanks!
Nick
Intermittent oil warning light pt2 sawdust123 General Turbo Discussions 24 13 Mar 2010 10:23 pm
LUMINICS head light and fog light bulbs 03baggedturbo Vendors & Buyers Forum 8 22 May 2008 08:36 am
Airbag light coming on SuzCruz Tech & Performance Forum 14 24 Oct 2007 08:11 pm
how to hook up a rear floor aux light pppt03turbo Exterior & Interior Styling 4 15 Dec 2005 09:57 am
Airbag problem - light and chime keep coming on cruiserbabe4 Tech & Performance Forum 9 22 Jul 2004 01:00 pm
