Cigarette plug not working
Old 03 Feb 2006, 09:31 am
Default Cigarette plug not working
The cigarette ligher/plug in my '01 PT isn't working. Checked the fuse box but didn't see any burnt fuses. Any suggestions on where to begin?
Old 03 Feb 2006, 12:37 pm
The power outlets in the PT are all under one fuse. That fuse is #19 in the fuse box located in the engine compartment.
P.S. The pink colored fuses are all spare in case you need to hook up accessories. Both my Aooga Horn and undercar LEDs use power from those fuses.
Old 03 Feb 2006, 08:15 pm
do you have the car on ?? im not sure if they just work like the old cars
Old 05 Feb 2006, 08:40 am
The cigarette lighter/power outlet on the dash area needs to have the car key to the "on" position. I always have my cell charging through that, then car shuts off and so does juice to the plug.
I too have a '01 PT as well. I am not sure of the plug on the floor console.
2001 Ltd Ed. Inferno Red PT, many mods, many more to come.
Old 05 Feb 2006, 09:27 am
My 2001 works exactly opposite. The power outlet in the dash area is ALWAYS ON, whereas the power outlet on the floor console is only hot with the ignition ON. [:I] Just went out to the garage to make sure, plugged the radar detector into the dash (without the key) and it lit up like a Christmas tree.
Old 05 Feb 2006, 05:35 pm
gonzomania's Avatar
Send a message via AIM to gonzomania
Carey, mine also works the way yours does. Also the one in the cargo area needs the key on
Old 07 Feb 2006, 12:26 am
My car is defective!!! :P
Would explain alot of things actually... lol
Old 11 Dec 2008, 05:01 pm
PeterMixt's Avatar
Default Re: Cigarette plug not working
OMG - I don't smoke but I sure wish my cig lighter socket worked... fuse 19? I'm gonna go check - so much to learn here..
thanks gang...
PeterMixt
Old 11 Dec 2008, 05:15 pm
crusierdad76's Avatar
My 06 the lighter plug has to have the key on to work you cant keep a cell phone charged unless the car is running OR the key is in the on position the one in that duffy consul which you cant ever get to is useless to me anyway so I have no idea how it works or if it even does
Old 11 Dec 2008, 05:21 pm
On the 01-05 cruisers, one lighter (12v outlet) is hot all the time whereas the other one needs the key to be on.
Oil drain plug AlmondTurbo General PT Cruiser Discussions 2 07 Feb 2007 04:54 pm
Rear Outlet Plug gonzomania Interior Accessories Forum 3 09 Feb 2006 06:34 pm
spark plug wires dzinman Tech & Performance Forum 1 28 Jul 2005 01:25 pm
Drain plug DREAM2 General Turbo Discussions 11 06 Jul 2004 10:14 am
remove power outlet plug ??? Jimbo Interior Accessories Forum 3 28 Feb 2004 07:20 pm
