Dealership & Tranny Cooler problem
Old 05 Feb 2006, 12:28 pm
Default Dealership & Tranny Cooler problem
My fiancee's PT was taken to the dealership under extended warranty to replace an automatic transmission that had gone bad. When she picked it up she made it about 5 miles before it over heated and dumped a lot of coolant.
She picked it up saturday and they told her Monday they will check to see if it related the transmission replacement.
I am wondering if the Tranny cooler is integrated into radiator and/or requires purging after an auto tranny install. Common sense tells me it is related.
I need advise to what the dealership needs to do to make it right. I turned the engine over and it didn't sound like she roasted it. (She has no clue to severity of the over-heat).
I am thinking as a precaution they need to replace valve cover gasket, and the thermostat. What do you guys think?
Old 05 Feb 2006, 06:34 pm
The cooler that's located under the car at the base of the firewall is NOT a tranny cooler, it's for the power steering. I don't believe the PT has a tranny cooler, although with the troubles that the transaxle is giving people, maybe a cooler would help. For your PT to overheat so fast after your service, it almost has to be something they did at the shop. Replacing the transaxle is pretty involved and loads of things have to be taken off or moved to do it. Good Luck.
Old 06 Feb 2006, 02:22 am
Do you know the year and model PT?
Is it a Daimler Chrysler "Service Contracts" brand extened warranty?
Is the dealer a 5 Star Chrysler daeler?
Has anybody else worked on the transmission before?
\'03 PT Turbo 2CN
Auto/Stick
Lt. Almond/cloth
Blanes HoodStruts
etc.
Old 06 Feb 2006, 10:56 am
Dunno until the cause is determined. Thermostat would be most lilkely.
I think you meant head gasket, not valve cover gasket - doubt they'd spring for that....
Disagree w/Crewzin - quite sure the PT has both - an auto trans cooler, AND a power steering cooler. The power steering cooler is much smaller.
Old 06 Feb 2006, 11:13 am
quote:Originally posted by quicksilverdon
[quote
[xx(] Your right Don. There is a Transaxle Oil Cooler tucked away under the car. The Turbo models have there's in front of the radiator.
Tranny cooler? sawdust123 General Turbo Discussions 2 07 Jun 2005 09:14 am
I think I'm having a power steering problem! lumofny Tech & Performance Forum 5 18 Jan 2005 01:12 pm
Unknown RPM surge problem (manual) Ctown Tech & Performance Forum 4 26 Dec 2004 08:48 pm
Tranny She is a no-good! scottscars Stage Turbo Kits 15 16 Oct 2004 11:11 am
Burned up 2nd and 3rd gears in Autostick tranny. Rainman General Turbo Discussions 6 16 Mar 2004 01:40 pm
