Noise from suspension???
Old 06 Feb 2006, 10:23 am
Default Noise from suspension???
I have this loud creaking noise coming from suspension area whenevr the car has been used for more than 15 minutes. It only comes when I am turning at very slow speed, like in a parking lot while turning nto a parking lot. It does not sound like a bad drive shaft, but more of like a rusty door hinge kinda sound. If its the drive shaft, often the sound will sound like few clicks while doing a full turn (uturn), but my car does not sound when doing u turn. I think that my suspension coils needs some grease, etc..but i dont know. anyone has experience???
secondly, is it normal for a pt cruiser to slighltly vibrate when accelarating on initial drive off? like from a stop to a drive off. i feel like a lsight wobble on my left front wheel then as teh speed gets fasterm the wobble is not apparent anymore. The dealer tols me that this is normal for all Pt cruisers. even the new ones have em. Is this true?
Thirdly, when idle (traffic lights), is it normal for the engine to shake intermittently like every 3 seconds. the rev meter is constant though at 0900 rpm. but the engine jerks/shake as if like a misfire. However, i have cleaned the injectors/throtthle body, changes new sparkplugs and wire. but problem still there. The dealer says its normal for this car. I beg to differ!
anyone can give comments/advise/piossible remedies? btw, my model is the baseline 2001 automatic with 68,000 miles.
Old 06 Feb 2006, 10:44 am
Welcome - you're the second owner from Dubai that I know of.
Have your ball joints checked for the noise.
You say wires & plugs were done - how long ago and with what? The stock wires are real garbage.
Old 06 Feb 2006, 08:23 pm
ruzz1, welcome to the Forum, enjoy!!!![^]
None of the conditions you describe are NORMAL for a PT. I assume that your choice of dealers are slim to none, If there is more than one available to you, take it to another one.
Old 07 Feb 2006, 12:23 am
Check out the topic I had started in the tech forums here...
http://www.ptcruiserlinks.com/forum/...TOPIC_ID=13832
Maybe there is a suggestion that can help you. I know there have been different people complaining about the same noises (just about) coming from the front.
2001 Ltd Ed. Inferno Red PT, many mods, many more to come.
Old 08 Feb 2006, 04:39 pm
I changed my spark plug and wires used by the dealer: MOpar products. just changed it a week ago.
on the wobbly/vibration tire feeling on initial drive off..anybody has experience? cud it be tie rods?
Old 09 Feb 2006, 01:06 am
Never had THAT problem... hmmm what's the wear pattern look on your tires? Look normal? Maybe they might need to be aligned... badly? :P
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Finally Energy Suspension kit installed+result Ctown Wheels, Tires, Suspension 4 02 Jan 2005 03:53 pm
Road noise / exhaust noise in the car. jackatg450 Tech & Performance Forum 3 21 Jul 2004 10:55 pm
Air Bag Suspension Noise Question ptcruzin42 Wheels, Tires, Suspension 0 30 Oct 2003 07:49 pm
Autocrossing with air suspension renichms Tech & Performance Forum 2 12 Apr 2002 10:29 am
